Reply 20 of 30, by KainXVIII
At least we found what cause this problem, maybe it will be useful for someone.
Reply 22 of 30, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
@collector: can you check whether it is because mt32emu is always enabled or by default and when you disable it, the roma don't matter?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 23 of 30, by KainXVIII
Does not matter, roms cause issues even if mt32 emulations is set to off.
Reply 25 of 30, by Yesterplay80
The command "mixer /listmidi" works with the win32 midi device only!
What I think is happening here is: The MT32 patch makes MT32 emu the new default midi device (which I don't like really). So if you start up DOSBox with "mididevice=default", it tries to load the MT32 emulator. If you set up your config pointing to the roms in the DOSBox directory and you start up, MT32 emu will successfully be loaded, but "mixer /listmidi" won't show nothing. Now if you remove the roms from the directory, the MT32 emu won't load and DOSBox does a fallback to the win32 midi device. And, as we now know, "mixer /listmidi" works with that one and will list the midi devices successfully again. Please have a look at your DOSBox status windows, I bet it looks like this:
The attachment DOSBox_win32_fallback.jpg is no longer available
As you can see here, DOSbox doesn't care if the roms are in the same directory:
The attachment DOSBox_win32_listmidi.jpg is no longer available
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 27 of 30, by Yesterplay80
Dominus wrote:
So, we should tell Sergm to change his patch that it doesn't set mt32emu as default 😉
I asked him how to change it, maybe it's no big deal.
UPDATE: Changed! Win32 is now default again.
Reply 28 of 30, by Qbix
Rank DOSBox Author
DOSBox Author
I added something based of this to r4015-4017.
Thanks rcblanke!
Water flows down the stream
Reply 29 of 30, by rcblanke
Awesome, thank you qbix!
Reply 30 of 30, by KainXVIII
Thanks rcblanke!
Work same way?
