bjt wrote:I guess there will need to be a more general solution for the Tandy sound card, like a PM TSR that traps all these things and redirects Tandy sound writes.
As far as i know the Tandy Sound Card approach was to place the sound chip on C0h / 1E0h selectable with a jumper. From what i could understand the last few months i launched the Tandy thread, a TSR is great for interrupt interception but not to read a memory location.
In fact i think having the hardware sit directly on the proper locations is the best approach. It should work great on XT systems (and theoretically it shouldn't be a problem on AT's as well) and no need for software that will require a 386.
For games that DO require to read the TANDY string there's 2 choices: either patch the games like you did or place the TANDY string at the proper location, creating a BIOS extension to do so, like 2M-XBIOS does vias the DOS prompt.
I went as far as changing the Tandy ROM BIOS and changing the string from TANDY to DANDY via hex editing on location F000:C078 and it was not a surprise games that rely on that string started to play PC Speaker music and having monochrome graphics.
bjt wrote:It doesn't use the Tandy string, but the Machine ID byte
Can you tell me the exact memory location of the byte?
