havli wrote:In Q3A the TNT2 really should be faster, imho.
On the other hand, all 3DMarks and both GLQuake + Quake2 results are in line with my own benchmarks, which I performed few years ago. http://hw-museum.cz/benchmark-2-1.php
Q3A is the only game (it's actually the demo), were I set the graphics quality higher than the default. I wanted one rather demanding test in there for faster cards.
Apart from that, it's a SIS chipset, default BIOS settings, no tuning. And all cards are benchmarked on the same system. When / if I ever go through all cards I have planned, I will redo everything on a different system 😀
At least for the V3, the results are also in line with previous benchmarks I've conducted. But I haven't done any TNT2 benchmarks before, so this is a first.
But will be cool to see how things change on other processors.
Havli, BTW great site. I often use it to compare and I admire the work you put in to get all these results. Very impressive.
