Post your 386 Speedsys results here
Reply 100 of 325, by Mau1wurf1977
dirkmirk wrote:
what scores do you get for the doom timedemo?
I will find out! Currently busy playing around with the SX-33 board. I replaced the battery, quite proud of myself considering I'm not good when it comes to repairing stuff. Video in the process 😀
I don't have any 30pin 60ns SIMMs, just 72pin. But I don't think it makes a huge difference between BIOS defaults and lower Wait States.
My YouTube channel
Reply 101 of 325, by elianda
Well, if you run Doom timedemo you can compare with default versus tuned. I think it may be in the range of 5%.
Youtube Channel
Reply 102 of 325, by Mau1wurf1977
I made two videos about this board with BIOS default settings:
Doom: (runs too slow) https://www.youtube.com/watch?v=gIQVUK9hhBE
Wing Commander (runs too fast): https://www.youtube.com/watch?v=fJ5BlmbCMBM
The score for Doom is 8539 realticks or 8.75 fps.
My YouTube channel
Reply 104 of 325, by dirkmirk
Would you kindly re-run the doom timedemo without the screen border but leave the status bar? ie one size less than maximum.
Still 8.8 fps is very, very good for a 386 system, I think mine only achieve about 6.8 or thereabouts, interesting as my systems have 60ns ram must be the chipset that gives that extra oomph, I noticed no performance difference between the et4000 and a 2meg cirrus logic 5434.
edit: Were you aware that you press F5 for low detail for Doom? Doom is perfectly playable on the 386 in Low Detail not that I suggest you do but back in the day it was a great compromise if that's all you had.
Reply 106 of 325, by elianda
One thing that might be of interest:
I had a look at the AMI Bios in one of my 386 systems dated 08/08/93 and the CPU detection routine already supports Pentium CPUs.
Youtube Channel
Reply 107 of 325, by carlostex
Motherboard: QDI U386WB
Chipset: UMC 481 and 482F
Cache: 128k 10ns
Memory: 4MB
CPU: AM386DX-40
FPU: No
Oscillator: Eclipse 100MHz
System is not stable.
Reply 108 of 325, by kixs
Are there any 486SX benchmarked with Speedsys? I'm wondering about the CPU/FPU issue that you can see when testing the 386 with a fpu and the score dramatically drops. I only have 486DX variants.
Visit my AmiBay items for sale (updated: 2025-02-16). I also take requests 😉
Reply 109 of 325, by Anonymous Coward
Carlostex, can you please run the test again with himem.sys disabled so you can do the memory test?
I recently bought a 100MHz oscillator as well. I am going to attempt 50MHz on my OPTi 495SX system. This chipset was used in 486 boards, so perhaps it will be able to handle the speed a little better.
Reply 111 of 325, by GeorgeMan
He's using an older version.
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 112 of 325, by Anonymous Coward
Okay, I tried my system at 50MHz. I am unable to operate my cache at this speed. I will try some faster modules (if I have any left). I think with no cache 50MHz isn't worth it. However, if you used a cpu with L1 cache like the 486SXL or an IBM DLC it might be worth it. I am tempted to try my 486SXL at 50MHz, but I think the last time I overclocked one I fried the cache. So in that case, I'd have to use an SXL2 rated at 50MHz (can be ran in single clock mode)
Reply 113 of 325, by Anonymous Coward
However, I also have a 90MHz oscillator, and this one seems more promising. I will post results when I am finished testing.
*update* OPTI 495SX best possible timings
Both tests are with L1 cache turned off. I don't have the control software installed on my system to make it work properly with SCSI at the moment.
TI486SXL @ 40MHz
TI486SXL @ 45MHz
Reply 114 of 325, by carlostex
Sorry i'm living in England and all my stuff is locked and stored at my folks place in Portugal. I'll be there early November but i'll hardly have any time to test this. I have a Turbo XT computer to build.
Reply 115 of 325, by carlostex
I've looked for one too on eBay but never found a single one. So i kinda gave up. Plus i have a suspicion that my branded 10ns cache might not be actually 10ns, but way slower. Again i don't think i'll have enough time to redo the tests with 15ns ones.
Reply 116 of 325, by Anonymous Coward
My 90MHz oscillator is actually not DIP18, I think it's DIP12 or something. It's shaped like a square. The Chinese seller rigged it up on an adapter that lets me plug into the socket on my 386/486 motherboards. You might be able to get by with a 45MHz oscillator if the motherboard has jumpers that let you use a 1:1 ratio.
Reply 117 of 325, by carlostex
I don't think i have any motherboard that allows that. I think the cache is the main problem as the system was quite stable if i turned the cache off. Performance of the system at 50MHz without cache was about of a 386DX-33.
Reply 118 of 325, by Anonymous Coward
I am not sure if it's a problem with the cache chips themselves. With enough waitstates it should be perfectly stable. I set my wait states all to the maximum which should have done the trick. However, the system was still not really stable. I think it's either a cache controller, chipset or motherboard design issue. Remember even many 486 motherboards can't run 50MHz properly.
Reply 119 of 325, by Anonymous Coward
I was looking on the internets for an award BIOS for my OPTi 495SX chipset board. I did not find it. However, I did find a nice MR-BIOS. It's much more flexible than my AMI BIOS. It gives me a super fast bootup time and improved DRAM performance. Here are my results for TI 486SXL at 45MHz with L1 cache OFF.
I was also able to get 50MHz going with L2 cache on...but the lower DRAM and SRAM timings hurt memory performance.
