What the hell is that?
First post, by Marty2dos
Hello,
I buyed GliDOS. Registration was not a probem. Because i would like played with
Texture Packs, FMV Packs, Audio Packs etc...
OS: Windows 7 SP1 X64 /7850 XFX/ IntelCore2Quad Q9550/ 8GB ram
I have the TR1 GoG Version and I have the original TR1 Gold Edition.
After the Intro in the "Glide Server" the screen is ... weg ähm.. nicht da... the Dosbox
or Glide Server screen is away, off but i can hear the Menu and the Demo level in the
background.
If in Window mode, the screen Gide Server is centered by the Main GliDOS Window.
Not good at a resolution eq 1280x1024. The Glide Server Screen is outside the display.
You need to Edit your Sources from psvoodoo?
Starte Glide Server v1.53b (c) Paul Gardiner 2001-2013,
Deutsche Übersetzung Dank an Volker Jung http://www.laraunlimited.de
VESA mode 0x101
VESA mode 0x101
Open core.avi
Open core.avi
Play FMV
WinClose
VESA mode 0x110
VESA cmd 4F07, 0, 0, 0
Open escape.avi
Open escape.avi
Play FMV
WinClose
VESA mode 0x110
Open cafe.avi
Open cafe.avi
Play FMV
WinClose
VESA mode 0x110
VESA mode 0x101
I tried the vdos32 version and told me was with Unlock... what... is Unlock for vdos and why?
After the unlock screen it pops with a messsage "zwldentries returned 0x0000002"
what is now "zwldentries returned 0x0000002". ?
The Screen Transitions with the FMV Packs is terrible. I have three Display and all displays Pops. On,Off,On,Off.. puhhh
Exitsts a command. how: glidos.exe <glideos_1_xx.ini> <game name description from ini>. If not make it so, please 😉
Actually, I bought Glidos Tomb Raider 1 for advanced mode to play but I would have that can save the money and put a normal Dosbox + 3DFX support and ready. sadly... 😒
After Hours Research to run: it now runs but the Joystick (USB (not gamport/Creative crd etc..)) doesnt works.
Uhm moment . My Xbox Wireless Controller works if i press Left or Right. The buttons doenst works and the
keyboard too. Yes, i press left or Right Arrow doent work. If i replace the glide2x.ovl with a other version from
gog archiv and it runs in plain Dosbox Mode, the controls work but not in "Glide server window"..
And please add -noconsole in your code. Running the game brings a fullscreen dosbox onsole.
--remote_fmv...DOSBox\dosbox.exe.......DOSBox\dosbox.exe <-noconsole> -conf DOSBox\dosbox-0.73.conf "%s" -c "mount d \"%s\"" -c "set PATH=d:\\.
I see in the UB Version the GliDOS logo. I think i buy the Prog. the logo is away?
Do you have e debug version?
Reply 1 of 4, by Glidos
Sorry, there's a fair amount of that I don't understand.
Use fullscreen mode and check the box that says: Kein Auflösungswechsel (wide screen) and choose a resolution that just fits within your natural screen resolution
Regrettably, VDos32 works only on 32bit windows
The wide-screen setting I mentioned above will help with that.
No other version of glide2x.ovl will work with Glidos.
--remote_fmv...DOSBox\dosbox.exe.......DOSBox\dosbox.exe <-noconsole> -conf DOSBox\dosbox-0.73.conf "%s" -c "mount d "%s"" -c "set PATH=d:\\.
You should be able to add -noconsole to dosbox-0.73.conf
Yes. No logo once you've unlocked.
Reply 2 of 4, by Marty2dos
Ok,
to 1: this is is ticked and the problem persists.
to 2: VDos32 is a 32Bit only Application, oh no....
this is totally unnecessary in the GliDOS Paket.
Huh, sorry, I had not even read. Stand somewhere.
to 3: this is is ticked and the problem persists.
to 4: Yes i know, this was only a test. But the Controllers
and keyboard doesn't recognized if 'Glide Server Windows'
appears. Because a Focus Problem?
to 5: this is a joke? Yes i can add and change the commando
but with a HexEditor, 🤣. You Execute Dosbox internal from
GliDOS. Told me how i can add the cmd without start dosbox
in GliDOS? In a Dosbox Configuration, is not bale to add
the cmd. this work only from Dosbox.exe cmd.
to 6: i like to say. I have buyed the prog and the logo is not
away.
Sorry, is meant no harm. but you did programmed the GliDOS?
Missed:
Do you have a debug version?
Reply 3 of 4, by Glidos
Marty2dos wrote:
Ok,
Maybe I misunderstood the problem. Maybe you mean, when in windowed mode, the Graphics window keeps being created off the side of the display. There's a fix for that. Move the initial Glidos dialog to the top right of the screen.
VDos32 uses Windows features that aren't available in 64bit versions.
In Windowed mode you are going to have the pain of the window disappearing and reappearing when swapping between game play and FMVs.
You should be able to just click on the graphics window to reassign focus.
to 5: this is a joke? Yes i can add and change the commando but with a HexEditor, lol. You Execute Dosbox internal from GliDOS. […]
dosbox-0.73.conf is a text file.
away.
You need to log into the website, enter the Glidos ID displayed by the program, obtain the key and install it.
Yes.
Missed:
Sorry. I don't understand.
Reply 4 of 4, by Marty2dos
thanks for that,
to 1: this a curious fix. do you think you can fix in the.
to 2: Which features use VDos32 in the 32bit version there
doesn't exists in a 64bit version?
to 3: this can but be fixed.
to 4: test it, doenst works. Left or Right works but the buttons doesn't
recognized. Keyboard is not working too.
to 5: How can i add the command -noconsole in the dosbox-0.73.conf.
in which ini section? I know is a text file. I mean HexEdit on Glidedos.exe
to 6: After the second unlock it works. puhh 😀
What did'nt you understand? my Question is
Exitsts a command line switches to start the from the
"glidos.exe <glideos_1_xx.ini> <game name description from ini>"
If not make it so, please. so similar to scummvm. with other words
glidos.exe GLIDOS_1_52.ini Name="Tomb Raider (GOG)"
Snip Ini -----------------------------------
Name: Tomb Raider (GOG)
Executable: B:\TR1\DOSHD\TOMB.EXE
ExeSizes:
CDPath: B:\TR1\IMAGE\TR1_PC_CD1.cue
Driver: Direct3D
MipMapping: No
PaletteTricksCache: Yes
ManagedTextures: No
NoModeChange: No
16BitColour: No
Edit: Can you add at the Glide Server Window an "Close" Button
