Reply 300 of 2299, by Totempole
- Member
wrote:It doesn't matter now, but you could put your ISOs on a networked drive, and it would still be as fast as a classic CD-ROM drive (probably 6x or so for Samba over 100mbit ethernet).
You can run some installed games over LAN as well: I actually set up an X-Com install on a shared drive on my LAN this week and pointed D-Fend Reloaded at it from two different machines. The only time I notice any delay is when saving my game, and it's much more convenient than having to zip the game folder and copy it across every time I switch which machine I'm playing on.
At one point I did actually consider using my main PC to store the ISO's,
but later decided against it. It would certainly have been more convenient in
terms of loading new games, but most, if not all of my games are already
loaded to the 500GB drives. If I need to add anything, I just use a USB
Drive and connect it through Mousepad Hub.
One thing that does slow things down a bit is Alcohol 120%. On startup, it
takes about a minute and a half to index all my ISO's, but once it's finished
loading, it works great.
Another problem I encountered was that games that need CD-Audio for
music tend to freeze up if you only have 1 sound card, because CD-Images
use Directsound to play CD-Audio, which is where the
Vibra 128 comes in.
