First post, by lwc
The readme wrote:
Example: For the file UZ.KL (keyboard layout for Uzbekistan) specify
"keyboardlayout=uz" in the DOSBox configuration file.
The integration of keyboard layout packages (like keybrd2.sys) works similar.
Alas, keyboardlayout=keybrd2 fails and keyboardlayout=keybrd2.sys gets DOSBox stuck. keyb.com keybrd2 and keyb.com keybrd2.sys fail as well.
So how can one load something from those sys files?
Thanks!
Reply 1 of 11, by wd
Rank DOSBox Author
DOSBox Author
What do you really want to do?
Reply 2 of 11, by lwc
I want, for example, the command keyb uz to require keybrd3.sys and not uz.kl.
Reply 3 of 11, by wd
Rank DOSBox Author
DOSBox Author
Put keybrd3.sys into the directory where you are when you execute keyb.com, or into the directory of your dosbox.exe
Reply 4 of 11, by lwc
If I put all four sys files, does DOSBox just look for UZ in all of them until it finds it?
Reply 5 of 11, by wd
Rank DOSBox Author
DOSBox Author
Sort of. There's a priority of the .kl over the .sys (keyboard/keybrd2/keybrd3) over the internal-compiled (.sys import) ones.
Reply 6 of 11, by lwc
No, I meant if no KL files are around does it look for UZ inside keyboard.sys, then in keybrd2.sys, then in keybrd3.sys and finally in keybrd4.sys?
What's the latter?
Reply 7 of 11, by wd
Rank DOSBox Author
DOSBox Author
Yes, see what I said. Except that keybrd4.sys won't be searched.
What's the latter?
the .sys files compiled into dosbox.
Reply 8 of 11, by lwc
Why not?
Reply 9 of 11, by wd
Rank DOSBox Author
DOSBox Author
Check the sources.
Reply 10 of 11, by lwc
I take your word that the sources also ignore keybrd4.sys. I just wonder why.
Reply 11 of 11, by wd
Rank DOSBox Author
DOSBox Author
Didn't exist.
