First post, by byte_76
I’ve got my hands on a Tekram P6PRO-A5 ver. 1.01
The board has an issue with one of the ram slots closest to the chipset and the floppy controller does not work.
When a memory module is installed into that first slot, the board beeps at power-on and won’t POST.
I checked for broken traces and missing surface mount components but did not find any damage.
There are no bent contacts in the ram slots and there does not appear to be any visible dirt but I’ll do a thorough clean later.
Does anyone know how to remove those white clips on the ram slots? I can get them from a spare parts board.
What should I be looking for in this case?
