First post, by vindasal
vindasal
Offline
This game runs very poorly on modern hardware/OSes, but dgVoodoo seems to get the framerate under control quite nicely. The caveat to this is that the videos that play on the menu and as bonuses simply do not work. I can't seem to find a setting/tweak that will fix this, I'm curious if anyone else has a fix because this seems to be a rather common issue.
