Reply 400 of 414, by BEEN_Nath_58
thaddeusjl@gmail.com wrote on 2025-03-30, 19:59:
Someone just gave me the MW2 Battlepak, doesn't seem to be compatible with this tool. Is there anything I can do to help get it compatible?
Overwrite the mw2installer files with these. After installation, copy the MW2SND.CFG to the game folder.
Caution: When playing missions, try to save the game after each mission. There are FreeLibrary errors so the game may crash on any mission launch
Reply 401 of 414, by BEEN_Nath_58
Updated installer with better memory management and support for Battlepack. Patched the winmm timer bugs thanks to @nervoushammer.
For Battlepack or Titanium Software editions, use the 480p mode using the .CFG file in attachment.
Installation of SDBs are tested to not be required, will be phased out at a later release
Update: the memory leak issue still exists. On investigation... The "better memory management" corresponds to correct memory freeing on mission exit
Reply 402 of 414, by Carrera
Thanks!
Reply 403 of 414, by BEEN_Nath_58
Carrera wrote on 2025-04-02, 09:40:
Thanks!
I have identified the mission memory leak, but I will need some time before I investigate it again. Other than that, almost everything else works. Maybe if 320x240 mode of Battlepack is excused 😉
Reply 404 of 414, by thaddeusjl@gmail.com
BEEN_Nath_58 wrote on 2025-04-02, 06:20:
Updated installer with better memory management and support for Battlepack. Patched the winmm timer bugs thanks to @nervoushamme […]
Hello!
Installation was successful. I get an error saying display must be set to 256 colors before proceeding. I'm not sure exactly what that means 🤣
Reply 405 of 414, by BEEN_Nath_58
thaddeusjl@gmail.com wrote on 2025-04-02, 13:18:
Hello!
Use this one:
The one you chose sets the desktop as 32-bit, while the one I linked changes the virtual surface to 256 color. I will merge them both later when I test all of the,
Reply 406 of 414, by thaddeusjl@gmail.com
BEEN_Nath_58 wrote on 2025-04-02, 13:32:
Use this one: Re: A comprehensive guide to install and play MechWarrior 2 on new versions on Windows. […]
Hello!
Use this one:
YAY! it works OMG I'm so excited. You sir/ma'am are a wizard. I haven't played yet so I don't know if it will bug or anything, but it booted and I watched the cutscenes. Minor thing I noticed is that in the filename it has a typo 'Centrury' instead of 'Century'.
Reply 407 of 414, by BEEN_Nath_58
thaddeusjl@gmail.com wrote on 2025-04-02, 13:50:
Hello!
Use this one:
Okay I will remember to fix that in the further updates. If you get any freezes or crash in mission, let me know
Reply 408 of 414, by thaddeusjl@gmail.com
BEEN_Nath_58 wrote on 2025-04-02, 14:29:
Use this one:
After playing a bit, it crashes when trying to open the holographic display in the Jade Falcon campaign. It crashed on the Help option as well, not the Keshik, the other one. I was able to load training missions fine. An error was popping up DLL something, but it didn't cause the game to crash. It was mostly happening when exiting a mission.
The mouse is inverted, and I couldn't figure out how to switch it. Up is down and down is up when moving torso.
Reply 409 of 414, by thaddeusjl@gmail.com
Here's a screenshot of the error message
Reply 410 of 414, by thaddeusjl@gmail.com
Oh and the game starts out in Windowed then switches to full screen when I launch a mission
Reply 411 of 414, by BEEN_Nath_58
thaddeusjl@gmail.com wrote on Yesterday, 01:52:
I just noticed the Holographic issue, checking now. About the Help option (Techical Help you mean), I don't think it crashed but rather kicked you out of the game to the browser? Technical Help uses the old WinHelp format which isn't available on Windows 10 and 11. It is possible to have it back, do a google search for WinHlp Windows 10 and you will get something.
The DLL error comes from the ANET code, which was buggy back in the day as well. Happens in other games like Heavy Gear 1. Safely ignorable.
Yes the mouse has always been inverted for me...
thaddeusjl@gmail.com wrote on Yesterday, 02:04:
Yes Battlepack is a fullscreen game. If you are talking about not being able to get to the shell after mission in windowed mode, that's a bug but I can't say when it is getting resolved. However I don't think it affects the game's playability much
Update: figured out the holographic crash issue: incomplete game installation
Reply 412 of 414, by BEEN_Nath_58
Updated the installer, making settings more Global. Memory leak should be gone in this release:
Reply 413 of 414, by thaddeusjl@gmail.com
BEEN_Nath_58 wrote on Yesterday, 07:14:
This should fix the holographic issue or is this for a different version?
Reply 414 of 414, by BEEN_Nath_58
thaddeusjl@gmail.com wrote on Yesterday, 20:49:
Yes this should fix it.
