Reply 55860 of 56001, by Kahenraz
- l33t
Trashbytes wrote on 2025-01-25, 07:03:Kahenraz wrote on 2025-01-25, 06:39:Trashbytes wrote on 2025-01-25, 03:15:What Xeon setup did you buy .. its a bit off topic but Im curious.
I opted for an ASUS WS C246 Pro with a Xeon E-2278G. It was in my budget and had a good balance of performance to e expandability. I prefer Intel at this time because of an of the regression errata that Ryzen has with 16-bit virtualization. It's a shame how broken it is. I used to have a Ryzen 1800X, but I got rid of it for this reason.
How does this error cause problems ?
I dont know a lot about Vm's so explain it like Im 5.
I got a good deal on the Xeon. It arrived damaged and I was issued a refund. I was able to repair it, although soldering onto the underside of a CPU was a royal pita.
Repairing damaged capacitors on an Intel Xeon E-2278G
Oh, and the motherboard shipped without a cover on the LGA socket with various detritus floating around inside the box. Building this system was fun times, for sure.
