First post, by gamer-stu
Just a PSA for posterity, in case you find yourself wasting hours trying to troubleshoot a failed install of DOS onto an IDE-CF card.
First step: make sure that a floppy power cable is plugged into the IDE-CF adapter.
That is all.
Reply 3 of 3, by gamer-stu
Shponglefan wrote on 2025-01-22, 21:48:
Is it plugged in? Is it turned on?
Solves 90% of tech issues.
Amen. What is weird is that I could read from the CF card without the power plugged into the IDE-CF adapter. I just couldn't write to it with the MS-DOS installer. Even EZ-Drive seemed to write to the disk fine. If it failed on everything outright, I probably would have realized my mistake sooner.
