First post, by PolygonYT
Hi. I'm Polygon. But you can call me Poly.
I'm getting a stupid discontinuation message:
https://imgur.com/a/farewell-winbox-JlHGvwG
Any way to stop it?
Thanks,
Polygon 😁
Any way to stop it?
Thanks,
Polygon 😁
Easy - you use a different manager. WinBox messes directly with 86Box's internals and due to the fact it hasn't been updated in over 2 years now, it's been causing numerous problems, misleading people to believe they're actually bugs in 86Box itself.
Battler wrote on 2024-08-06, 18:17:Easy - you use a different manager
Turns out it's not that easy. Can't seem to find any other manager for Windows...
What's the last line in the message?
I built:
Dos+Windows 3.11 auto-install iso template (for vmware)
Imgema wrote on 2025-01-03, 15:50:Battler wrote on 2024-08-06, 18:17:Easy - you use a different manager
What about 86Box Manager (https://github.com/86Box/86BoxManager)? Using that one myself.
86Box Manager is good. I used to use it too.
But now stopped using front-ends altogether. Using direct shortcuts with the --vmpath parameter. And I have created shortcuts on my desktop for the "systems" I use most often :
I'm using Debian as my main OS, but this should be easier for Windows users too.
