First post, by tauro
What the hell is this?
2x SLOT 1 or SLOT A?
5 PCI-X
1 PCI
1 ISA
On the left side, what is that big CPU-looking chip?
Is that the Dell ATX 20+6?
Edit: The thread was formerly named "ID motherboard"
Reply 1 of 14, by AlaricD
It looks like... some sort of motherboard. Slot 1, not Slot A, from the orientation of each of the slots' keys. Definitely not Slot 2.
I don't think we'll get much more out of a 227x253 blur like that.
Reply 2 of 14, by paradigital
Assuming the image hasn't been flipped then that's BTX, which must narrow it down a touch?
BTX seems a bit late for Slot1 (or even Slot2).
Reply 3 of 14, by PcBytes
Dell PowerEdge 2400 mainboard. Yes, frankly enough, it seems to be BTX, or at least a predecesor of it.
Reply 4 of 14, by tauro
PcBytes wrote on 2025-01-06, 15:46:
Thank you, legend.
According to the manual it supports Pentium III.
I'll get it and see if it works!
Reply 5 of 14, by tauro
It arrived!
The attachment dell.poweredge.2400.jpg is no longer available
It seems it was stored for a long time. It has some minor damage. Someone removed the battery holder and the buzzer. Other than that I couldn't detect other missing components or critical damage, but it's still a mystery whether it will work or not.
Now I'll have to get one of those pseudo-ATX Dell PSUs with a different wiring, or maybe create an adapter. What do you recommend? I'm guessing it needs a lot of current with all those chips onboard.
I'm surprised that it has what it looks to be an x86 CPU in its own right (GC80960RM100) soldered on. I assume it's part of the chipset. Does anybody have more info on what it actually does?
The attachment gc80960rm100.jpg is no longer available
Reply 6 of 14, by Mov AX, 0xDEAD
tauro wrote on 2025-01-08, 21:37:
Intel i960, seems like part of SCSI subsystem on board
Reply 7 of 14, by debs3759
80960 is completely different to x86. I think it's RISC. Can't comment on what it's being used for here, other than maybe cost cutting 😀
Reply 9 of 14, by myne
Gotta remember, chips fit inside packages.
The package can look the same, but contain completely different chips.
This package looks similar to the slot 1 celerons or 423 p4s but obviously isn't.
Same as you can't accurately guess what is in an atx case by looking at the outside. It could be anything.
I built:
Reply 10 of 14, by darry
Be careful.
Apparently, this [1] works (have not tested myself) and may or may not be the same as what was used in consumer grade pseudo-ATX Dell PSUs.
[1]
https://www.dell.com/community/en/conversatio … 4ccf8a8de01ce26
Reply 11 of 14, by dionb
Tiido wrote on 2025-01-09, 11:10:
Probably part of a RAID controller.
Yep, it's a general-purpose CPU purposed to do parity calculations for large, complicated (RAID 5 or 6) RAID arrays on the SCSI bus.
The motherboard chipset looks like a Serverworks IIILE chipset - no AGP, hopelessly buggy IDE, but huge memory bandwidth and big PCI buses. Also onboard RageXL PCI, for what that's worth.
Great board for a retro server or non-graphical workstation. Just don't use the IDE, not even for a CD drive. Sort of echoes the old CMD640 😉
Reply 12 of 14, by tauro
It's indeed an i960, I didn't know about them. It was Intel's attempt at creating a RISC processor. It has such an interesting story. Just an excerpt from Wikipedia:
Myers tried to convince Intel management to market the i960 (then still known as the "P7") as a general-purpose processor, both in place of the Intel 80286 and i386 (which taped-out the same month as the first i960), as well as the emerging RISC market for Unix systems, including a pitch to Steve Jobs for use in the NeXT system. Myers was unsuccessful at convincing Intel management to support the i960 as a general-purpose or Unix processor, but the chip found a ready market in early high-performance 32-bit embedded systems.
Now about the PSU:
darry wrote on 2025-01-09, 21:02:
Be careful. […]
Be careful.
[1]
Thank you very much for that!
I checked the GND pins for the 24-pin connector on the board and they match. I don't know how I could confirm the other pins are right but it looks promising.
I found this which coincides with the pinout you linked:
https://web.archive.org/web/20240916103400/ht … su_pinout.shtml
But there's also the 16-pin connector (P2). I checked it with a multimeter and there's no continuity between any of its pins and any of the 24-pin ATX connector pins. Furthermore there's no continuity between any of its own pins. So I'd need a bit of help with that. Should I just leave it alone and try to start the motherboard with the 24-pin connector only? What about the pinout from the website I linked?
This is the visual representation of what I have so far (I'm ignoring the "TFSC"):
The attachment 24pin.pinout.png is no longer available
The attachment 16pin.pinout.png is no longer available
I have to get this straight before creating the adapter because it will take a lot of soldering and I want to do it a single time.
Reply 13 of 14, by tauro
dionb wrote on 2025-01-09, 21:51:
RageXL PCI is not bad for regular DOS / 2D Windows games I suppose. If I get it to work I'll do some tests with better PCI video cards.
Thanks for the heads up! After I read what you wrote I looked for the IDE interface and... I couldn't find any though! 🤣
Reply 14 of 14, by dionb
tauro wrote on 2025-01-10, 22:56:
I thought the blue connector next to the 50p SCSI was IDE, but seems I can't count and it's floppy. Dell did the sensible thing and didn't even implement it 😀
Also, my eyes are going and it's a Rage IIC, not RageXL.
