First post, by vvbee
S3d is the name of the hardware 3D engine in ViRGE. S3d Toolkit Library is S3's C API for programming the S3d engine. What I'm talking about is the performance of the S3d engine as programmed using the S3d Toolkit Library. The performance of S3d for short.
I wrote a test scene based on one of Tomb Raider's levels. It consists of about 400 triangles of completely static, fully textured geometry. All transformations are baked into the mesh, little runtime load on the CPU. Supports the DOS and Win32 versions of S3d.
The attachment s3dtr.gif is no longer available
The first results on a ViRGE/DX at 640 x 480 with an Athlon 64, vsync disabled:
The attachment ca6cf42ef3c9.png is no longer available
Though all were run from Windows 98, the DOS versions tended to run faster, which isn't too surprising.
The ViRGE isn't a 640 x 480 platform and the numbers show it, but non-textured performance isn't too bad. The non-textured test used a black color for all vertices, which may or may not affect performance. Ideally I'd pick a color from the texture, and I might make that modification.
What surprises me is that getting rid of screen clear (S3DTK_RectFill) had no impact on performance. I'd expect it to be a relatively fast operation, but not that fast.
That removing perspective correction made no difference in FPS might or might not be due to the particular geometry of the scene, which again is also static.
UV and XY range guards (S3DTK_VERIFY_UVRANGE | S3DTK_VERIFY_XYRANGE) were always enabled. I don't know about the UV coordinates, but there's slight XY overflow.
Reply 1 of 6, by Joseph_Joestar
I'm guessing you already know this: pressing F2 in while running Tomb Raider in S3D mode will display the frame rate. You can then leave the game at the main menu for a bit, until it starts playing the demo, which will keep showing the frame rate.
If you capture that demo loop, you may be able to get an average frame rate value. I think @BitsUndBolts wrote a utility that would go over every frame of the recording, grab the FPS numbers and put them in a spreadsheet. You can see him using it near the end of this video.
Reply 2 of 6, by vvbee
Joseph_Joestar wrote on 2025-01-05, 19:08:
Using a custom renderer has the benefit of being able to toggle more options, and to run the same test using the DOS and Win32 versions of S3d. I do also have a custom capture program that can estimate and average the FPS regardless of whether the game displays it, but what I'm also interested in is the S3d developer experience, which in-game benchmarks won't tell me as much about.
Reply 3 of 6, by analog_programmer
Nice! The screenshot reminds me of the first room in TR1's "Tomb of Qualopec" level 😀 I know it, 'couse TR1 game is my "universal DOS test" for S3, 3dfx, Rendition and Matrox (unfortunately I can't get any PowerVR PCX1 or PCX2 cards) first (sometimes second) generation of 3D videocards and their proprietary APIs.
Does your test-demo has an option to change the resolution to a lower one (320 x 240 or 512 x 384)? TR1 at 512 x 384 on a fast (70+ MHz) S3 ViRGE/DX or GX is almost "playable" as for the mid '90s 3D gaming standards 😁
Do you intend to share your test-demo?
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
Reply 4 of 6, by marxveix
S3 Virge GX2 is the fastest i think and one of the first AGP cards.
30+ MiniGL/OpenGL Win9x files for all Rage3 cards: Re: ATi RagePro OpenGL files
Reply 5 of 6, by Putas
vvbee wrote on 2025-01-05, 18:55:
Parallelization of perspective correction is expected from the /DX. You might want to try to disable all the other features except texturing to see if there is a difference.
Reply 6 of 6, by vvbee
Tests in 512 x 384 and 320 x 200 with 16-bit color on the ViRGE/DX (driver 3.42), same as before:
The attachment f2d69debeb5d.png is no longer available
The attachment a10cd6d91557.png is no longer available
Unlit texture means texture colors aren't blended with vertex colors. For whatever reason disabling bilinear filtering had no real performance improvement in the DOS version at 320 x 200, double checked. Screen clear continued to have no obvious effect on performance, but visually it's being done.
Baseline difference in performance between the DOS and Win32 versions of S3d at different resolutions:
The attachment b49feaf05cbe.png is no longer available
Direct3D 5 performs about equal to the Win32 version of S3d on the ViRGE/DX:
The attachment 7f98bd176154.png is no longer available
Not sure what's going on at 512 x 384, something's holding S3d back. I double checked the result. Visually, Direct3D has problems with alpha reject.
Putas wrote on 2025-01-06, 05:51:
I'll see about this.
