First post, by Shponglefan
- l33t
Following on the recreation of our family 1997 Pentium MMX 166 PC, I've decided to create an alternative 1997 'fantasy' build. This is based on what could have been possible for a 1997 Pentium MMX based system. I'm not doing a build based on the Pentium II, since I have another 1997 build intended using a Pentium II 300.
Outside of using compact flash for fixed storage, this is intended to be a period correct 1997 build. All components are based on what was available at the time.
Planned specs include:
- Pentium MMX 233
- Magic Pro MP-586ACT motherboard (Intel 430TX)
- 64MB of SDRAM
- Riva 128 PCI
- Orchid Righteous 3D (3dfx Voodoo)
- triple ISA sound card setup (TBD)
- 3.5" floppy drive
- 8x Mitsumi CD-ROM
- CF-to-IDE adapter + 4GB CF card
- AT case + PSU
The heart of the system is this Magic Pro MP-586ACT motherboard. I chose it specifically because of the physical layout. While I have other Socket 7 / 430TX boards, most of them have obstructed ISA slots. This makes installing multiple ISA sound cards more of a challenge. This Magic Pro board has relatively unobstructed ISA slots allowing for more sound card options.
It features 512kB of cache, but there are a couple unpopulated spaces for additional cache. Apparently certain configurations of this board came with 1024kB. Not sure if it's worth trying to upgrade this board, but that is something I might experiment with in the future.
The only caveat is there isn't much information on this specific board. The Retro Web lists it as a variant of the Soltek SL-54P2, but I can't find any BIOS ROMs or manual for this specific board.
For the CPU, I'll be using a Pentium MMX 233. I considered trying a Tillamook MMX 266, since this board seems like it could support the necessary multipliers/FSB. But based on everything I've researched, it sounds like L2 cache would be a problem trying to use it in conjunction with 430TX boards.
Video cards will be a Riva 128 (PCI) and a Orchid Righteous 3D. Based on my testing of various 1997 era PCI video cards, the Riva 128 seems to have the best combination of performance and compatibility. Pairing it with a Voodoo 1 card seemed a logical combination.
I also considered adding a PowerVR card, but I'm not sure it would be worth it with a Pentium MMX. From everything I've read, those cards are highly processor dependent and anything less than a Pentium II isn't recommended.
