First post, by Linoleum
- Member
Finally received my Compaq Prolinea 4/50... Very clean and soldered battery has been replaced by a battery pack. Heck, it even recognized my 4GB CF at first try...
I tried installing an Audician 32 plus (clone) on the riser on any of the 3 ISA slots and the card would be detected... But in SETUPSA I would not hear a sound. So, tried my SB16... DIAGNOSE found the ports, IRQs, but could not find any available low DMA available. So, I disabled all serial and parallel ports just to be sure... The problem remained.
I launched the COMPAQ diagnostic disk and everything came out working properly (except sound, of course). So I decided to pull out the riser card for inspection... Visually, it's in perfect condition. But after testing all (super tiny yellow) capacitors for continuity (directly on PCB) I found 4 caps without any continuity: C106, C107, C120 and C121.
Is this a proper diagnostic and just replacing those caps should do the trick? If so, how do I know what are the specs for these caps?
P4 1.8Ghz, V3, SBLive
P3 866Mhz, Riva TNT2, SB Audigy
P2 300Mhz, TNT, V2, Audigy 2ZA
P233 MMX, Mystique 220, SB 32
P100, S3 Virge GX, AWE64, WavetablePi & PicoGus
Prolinea 4/50, ET4000, SB 16, WavetablePi
SC386SX 25, TVGA8900, Audician32+
