Reply 54440 of 55560, by jelabarre
Over the weekend picked up an HP 620LX Win-CE unit (works too, just had to dig through my power adapters to find one to work with it). It even has a 3Com 56K cellular modem PCMCIA card (what spec would that run, 2G?).
At the same flea market found a Twinhead Subnote 486slc. Just like the 620LX it needs a CMOS battery, but unlike that one I don't know where it's located on that one. It's going to take a bit more researching for that one.
Back in the spring I had found a 2010 27" iMac that just needed the memory replaced, although that one's been giving me grief trying to get a stable install on it. Doesn't power up now, if I don't fix that I'll probably convert it to a monitor (the resolution on that is much better than the 27" monitors they sell at Staples & bestBuy)
