New display adapter nextstep 3.3
Reply 20 of 34, by fosterwj03
I kind of want to install NextStep on my Pentium MMX system with my Stealth 64 (the one with the Trio64 chip) to see if I can replicate your issue. I just don't know if I have time for it.
Reply 21 of 34, by APOPAP
Thank you...I wonder if your motherboard is based on the same chipset as mine and what would be the results with trio64v+
Reply 22 of 34, by fosterwj03
It has an Intel 430VX chipset (Triton III). Hard to say if I'll see the same issue.
Reply 23 of 34, by APOPAP
I am curious to see...
Reply 24 of 34, by fosterwj03
I swear, I've never seen such a finicky installer. It didn't work on my Pentium MMX at all (it wouldn't read from the optical disk drives no matter how I configured the arrangements of drives [although the Pentium system has its own quirks]).
I'm finally getting it installed on a Pentium 4 with the Trio64 video card installed. I had to set the partition size to 512MB just to start moving files over from the optical drive. I'll migrate over to the Pentium MMX system once I have a working OS on the SD card.
Reply 25 of 34, by APOPAP
Nice,I also had a problem installing it.( I first set cd rom ide to 1:0 and disk 1,2gb to 0:0).
For drivers,I didn't load anything from device drivers disk,I inserted beta drivers disk and first I chose "adaptec 154x series scsi adapter"(Only by choosing that first worked,strange) and then "primary/secondary dual controller device driver"(by hitting 7) and then continue.
Reply 26 of 34, by fosterwj03
OK, so I got a blank screen once I installed the drivers for the Stealth 64 DRAM on the Pentium 4. The system gave a kernel panic when I booted into verbose mode. I don't know how to boot into basic VGA mode now that I set the system to use the Trio64 driver.
I wonder if the Trio64 is just a bit of a dud in NextStep. I'm going to reinstall NextStep on my Pentium 4 with a Cirrus Logic PCI card (GD5446) instead and see if it works better.
Reply 27 of 34, by APOPAP
When you normal-boot ,does the blank screen appeared after nextstep booting window or after pressing enter on boot:?
Reply 28 of 34, by APOPAP
Also does Config=Default helps?
Reply 29 of 34, by fosterwj03
I got an error message when I enter Config=default (something about a missing configuration file).
Yes, it went blank after proceeding from the Boot: prompt.
Reply 30 of 34, by fosterwj03
Boy, I've tried three different PCI cards, and none of them have worked beyond BW VGA. I'm out of time to troubleshoot. Maybe I can try again next week.
Reply 31 of 34, by akimmet
I always remember trouble getting color modes working with NeXTStep 3.3 on PC hardware.
OpenStep 4.2 with Patch 4 has a generic VESA driver that is easier to get working.
If you haven't already, make sure you have NeXTStep 3.3 Patch 3 installed.
Reply 32 of 34, by APOPAP
fosterwj03 wrote on 2024-09-22, 00:11:
Yes,unfortunately is very selective about the hardware will run on.Anyway,thanks for trying.
Reply 33 of 34, by APOPAP
akimmet wrote on 2024-09-22, 02:13:
Ok,I am going to try this out.
Reply 34 of 34, by dr.zeissler
I made several attempts to install nextstep on different machines. The only one that gave me no kernel panic at installation has a et4000w32 onboard. the et4000 driver does work in 1024x768 but only b/w...is there an updated et4000/w32 driver and if so how to install an additional driver? thx!
