Reply 160 of 321, by NHVintage
So reviewing the card, I guess you can use the USB for devices but not memory sticks. That's too bad, I guess I'll have to take up a slot with the ISA-USB card after all. The reason this matters is that it's just not easy to get a larger-than-floppy file onto the pc using picomem. You have to incorporate the file onto a HDD image before popping the miniSD card out of the back of the PC, putting the image into the HDD folder, and because you can't swap HDD the way you can FDD, you need to reboot the PC. A real chore.
Contrast with the ISA USB, you just put the file on the stick and plug it in. And the USB stick can even be on an extension so you don't have to reach around the back to access the USB stick. Plus, since you can add an XT-IDE ROM to the ISA-USB, it makes that functionality on the picomem less valuable.
My XT machine has limited slots, so I was hoping not to have to take one up with the ISA-USB. From what I see so far, the picomem lets you eliminate a dedicated XT-IDE HDD emulator , a Gotek (though in my case the board has a built in FDD controller, so I'll probably keep that for the convenience of not having to reach around the back), an Adlib or it's clone (but I may keep my SAAYM sound card as it emulates other sound cards often needed), a RAM card (though I believe in my case I'll keep using the RAMBank as it will allow more and faster memory and in that particular card's case a virtual disk). It adds valuable functionality: Wifi and limited USB joystick and mouse functionality.
So, basically, the Picomem is a good alternative to an XT-IDE CF card. It's the same price as one, or cheaper, and has additional functionality the other lacks. It's also a good alternative to a Gotek FDD emulator, even if the Gotek has Flashfloppy on it, if you don't mind reaching around the back of the PC to access the SD card (especially if the PC lacks a FDD controller). It's great for adding EMS to a 286 or 8088 system. But it's not quite the "one card to rule them all" - yet. Being a software controller and open source, it's entirely possible that future development may add new functionality and improve the existing. Worth the purchase? Oh yeah, most definitely!
