First post, by Dan386DX
Hello!
This card was inside a Socket 7 machine, the PC itself was sold to me as non-working and had been in storage for at least 20 years. PC came back to life with with a new PSU.
REVEAL K2Y-PRO16 - with a Yamaha OPL3 chip! Great score!
Windows 98 auto-installs the drivers, it detects it as..."Soundblaster emulation hardware" in device manager.
The trouble is, it has a looping issue, for instance, if I go to the default sounds and play the chime wav file, I don't just get a ding, but a dingdingdingdingdingdingdingding... endlessly, until I shut down the PC.
If I try to play a music file, it will play the first half-second of the track and then loop it endlessly.
I tried it with another system and got the same results.
So is this likely to be hardware related, or a driver thing? I've only tried it in in 98SE, but I can't seem to find a proper driver after some extensive googling. DOS Days has a snippet about a similar card, and says there are known Windows issues, but that one uses a different chip altogether. Of course it could be hardware, the caps look...okay, but I can't vouch for how well this was stored.
90s PC: IBM 6x86 MX 233MHz. TNT2 M64. 256MB RAM, 2GB CompactFlash.
Boring modern PC: i7-12700, RX 7800XT. 32GB/1TB.
Fixer upper project: NEC Powermate 486SX/25. 16MB/400MB.
Reply 1 of 4, by Grem Five
Looks the same as https://www.dosdays.co.uk/topics/Manufacturer … sonic_sound.php or close to a http://dosdays.co.uk/topics/Manufacturers/tur … /montecarlo.php
Unless mistaken you should be able to use a OPTi 82C929 driver
I have an Acer Magic S20 and its 'close' to the same card with the same main chips.
Old thread but might sound familiar OPTi MAD16 and Win9x
Reply 2 of 4, by Dan386DX
Grem Five wrote on 2024-07-14, 00:57:
Looks the same as https://www.dosdays.co.uk/topics/Manufacturer … sonic_sound.php or close to a http://dosdays.co.uk/topics/Manu […]
Holy crap! The 82C929 Win9X driver fixed the issue immediately! You are a living legend, I can’t thank you enough.
AND it’s so much clearer than the Vibra I was using before, can’t wait to play some LucasArts titles now.
Thank you again!
Reply 3 of 4, by dionb
Good to hear 😀
Just wondering - what's so unusual about the card? Looks like a pretty standard 1994-ish card that - if the analog circuitry isn't too noisy - would be great for DOS and Win3.x but nothing really stands out. Or am I missing something?
Reply 4 of 4, by Dan386DX
dionb wrote on 2024-07-17, 23:03:
Good to hear 😀
It's not that unusual in that respect, I'd just never seen a Reveal branded card with an OPL chip!
You're absolutely right about it being a beast of the DOS age, while I've got it working in Windows 98, it doesn't play well with LucasArts titles in Windows 98 at all; in DOS, no issues.
