Need For Speed 3 works with ATi 3D CIF also, just make nfs3.bat file with nfs3.exe - ragepro in it and it uses rage pro mode, it needs ragea.dll inside main nfs3 folder, that i took from NHL 99. Menu is buggy right now, but the game can be configured well @ nfs3 graphics settings, it is using CIF, thats for sure. After nfs3.bat execute my driver or setup at the moment needs resolution or color depth change from windows and then game starts normally @cif. You can see all the other nfs3 -commands if you make mistake in the command line. If i rename windows/system/ati3dcif.dll file the game does not start and gives error, also nfs3.bat and the graphics look different with cif vs d3d or software mode. Many other -command options available for nfs3.
Need For Speed (NFS4) does not have -ragepro command support, but even there it is possible to trick it and start cif mode, menu text is unreadable, but game playable with screen errors , i just used quickly d3d and voodoo2 names for ragea.dll (nba 99) file and removed 3dsetup folder for my quick test and the same color depth or resolution change needed to start ati 3d cif mode with nfshs.exe.
NFS3 works better out of the box with ATi 3D CIF!
Someone has more Rage 3rash Modules (ragea.dll) files?
1998.08.13.1400 NHL 99 / NFS3 (works) bugs in menu
1998.09.15.1730 FIFA 99 / NFS3 (works) bugs in menu
1998.09.30.1645 NBA 99 / NFS4 (works) unreadable menu
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
