First post, by pshipkov
Anyone ever got these two SCSI controllers to do anything useful ?
The ones here refuse to cooperate.
A while ago bought AHA-1535A from Ebay seller.
Its BIOS never starts initializing during POST.
I thought the controller is busted. Seller refunded me.
Bought a second controller since then - same.
There is a chance both of them are broken, but i doubt it.
Both are in very good physical condition.
The situation with Always IN-2000 is different.
BIOS kicks-in during POST but never recognizes the storage device.
I don't have SCSI HDDs. Only CF cards through ZuluSCSI and Acard adapters.
So maybe something there.
Long ago had another IN-2000 controller who exhibited the same issues.
Am i missing something here ?
retro bits and bytes
Reply 1 of 15, by maxtherabbit
The IN-2000 you sent me works fine. If I recall correctly it only works on the default I/O port, if you change the DIPs to something else it will just silently detect nothing
I conversely only have real SCSI spinning rust, no solid state abominations. 😉
Reply 2 of 15, by pshipkov
Ok, that is a good sign.
Can you confirm the state of the dip switches - just in case i keep doing the wrong moves here ?
Reply 3 of 15, by Horun
The 1535 is a PnP type ISA and has a weird bios. I used the DOS Adaptec 1535CFG files to enable the Ctrl+A on mine a few years ago (in 2019?? irrc)
Here is the CFG util and a Hex of the text of what is inside...
Reply 4 of 15, by pshipkov
Thanks.
Yes, it seems like a weird contraption.
Can you confirm that the SCSI BIOS actually initializes during POST ?
If so - what hardware you tested on ? Motherboard, etc.
Reply 5 of 15, by Horun
Will have to find the card and see what notes I left. There are some OEM 1535 that the bios can be enabled but will not give the Ctrl+A, they came with some scsi CDR burners iirc....
Reply 6 of 15, by pshipkov
Ok, let me know if you get to it eventually.
So far 2 different cards don't do anything at POST.
Reply 7 of 15, by Horun
Found the card with driver floppies but not much for notes other than it works and BIOS does not show on boot. Think I have some pictures of testing the scsi card in my older phone, will go look.....need to charge it first
Reply 8 of 15, by pshipkov
Do you remember what class hardware you tested the card with ?
So far i tested mine on 286 and 386 machines, but want to see if it will behave differently on 486 and later ones. Maybe is missing instructions or who knows what in the early generations.
Unlikely, but still.
Reply 9 of 15, by Horun
It tested was on a Pentium board, found a few pictures but not of the boot screen. I should retest it and make some good notes.
Reply 10 of 15, by pshipkov
Thanks.
Ok, will run it today on 486 and P3 class mobos.
Reply 11 of 15, by pshipkov
Ok, made the Always IN-2000 guy work.
Turns out it does not handle well higher ISA bus frequencies.
Had to slow things down to 10-15MHz to get it rolling.
Something interesting - it can boot from disk partitions previously created on CF/SD cards through IDE controllers. Very useful.
Reply 12 of 15, by Horun
Great ! Do you have the manual and aspi driver for the In-2000 ?
Reply 13 of 15, by maxtherabbit
I found the Always ASPI driver on the metropoli BBS archive
Reply 15 of 15, by Horun
Yep max ! the In2_as.zip file is good. the DOS and Netware zip has dupe headers (as all small case and all caps for same files), it needs be extracted carefully.
The manuals in text are/were on Programmers corner, grabbed em a few years ago.. Stason is just a TH99 website...
attached the manuals
added: because the In-2000 supports HD's w/o any aspi driver, the aspi driver is only needed for cdroms, tapes, zips, etc with their drivers iirc.
