Reply 52960 of 56499, by RetroPC_King
Ozzuneoj wrote on 2024-05-17, 15:21:RetroPC_King wrote on 2024-05-17, 14:57:Ozzuneoj wrote on 2024-05-17, 14:49:Did you notice all the corrosion on the PCI contacts? If you use a pencil eraser to clean that up it may work fine. If there are any stubborn "chunks" you may need to scrape gently with a tool, just be careful not to damage the contact any more than it already is.
seen the corrosion, I will try to use the pencil eraser.
Also, I would use a brush to clean all that crud off the card, just in case any of it is conductive enough to be causing problems. I have revived cards just by brushing them off many times.
Thanks for the advice! I Will try it. ALso, the brush without rubbing alcohol?
