First post, by daerlnaxe
daerlnaxe
Offline
I work on projects with qemu on windows, i don't know why but on some games like fallout or commando i have a problem on cinematics. On fallout music seems normal but i have a freeze every n seconds. I well identified on commando, before the freeze sound is too quick.
I tried to use grab, vm is patched with pacher9x. With grab it's worst. I use cpu-z with normal mode i have 3.6g Ghz to 4Ghz. With Grab, i don't know why but i reach 6Ghz... i ask myself if qemu doesn't use all core.
In all cases i can't see for a while how to deal with it. I didn't notice any problem on starcraft before.
I ask myself if a software able to regulate cpu can be used without problem from the guest.
