First post, by myne
Hey all,
Got bored, and like most bored people I decided to play with a 30 year old obsolete OS.
Basically I made an auto-install iso which automatically does the following:
1) Installs dos (tested with 6.22)
2) Installs Win3.11 + TCPIP + VMware's virtual AMD network card
3) Installs Soundblaster 16 drivers
4) Has the option to run a modified and a bit problematic modified svga driver (google for info about the patch).
How to use.
Copyright dictates that it's not a complete iso. It's a template you'll have to fill with your own presumably licenced files.
I suggest using ultraiso to:
1) Copy the contents of your dos floppies into the dos622 folder
2) Copy the contents of your win311 floppies into the win311 folder BUT DO NOT OVERWRITE ANY EXISTING FILES
3) Save/burn
4) Install (<5min - most of the time is taken up by the cdrom driver loading every reboot (~5). True story.)
Installation process.
Most of the time it's just hitting enter when required. There's one expected error where you have to press A. It's noted.
Once you're in windows, try the modded display driver, reboot a few times if it hangs and see if it starts working.
Notes
1) This was built with vmware player and is therefore built around whatever quirks it may have.
2) It should still work on real hardware because it doesn't modify anything important
3) The setup kinda assumes the drive won't be formatted at all. It will do the fdisk stuff and continue. It MAY work on a formatted drive. See #1
4) The modified svga driver is called SVGB256.drv. It shows in the standard "change video" area of the setup as "0 VMWARE Patched SVGA 1024x768x256". It is renamed so it doesn't interfere with the original SVGA256.drv or it's settings (ie so the iso can work on real hardware too)
5) The modded svga driver WILL disable filesharing. I found that little tip when I was wondering why it's so glitchy. It may... just freeze sometimes on boot. Not sure if that's the driver or just vmware. It worked after a few reboots on mine. It will glitch out if you use a dos window. Don't.
6) If the svga driver glitches to the point you can't handle, run the c:\windows\setup and change to vga to fix it.
7) The files currently in the win311 folder are modified setup text files, winfile (y2k update), and the TCPIP addon. These are free to distribute AFIK.
😎 No guarantees. No support. It works for me, if it doesn't work for you I don't really care.
9) Try with/adapt it to other versions if you want. Compare the infs. See the tricks that make it work.
10) I'll probably never run it again. It was just a puzzle to solve to automate it all to a fairly clean and working state.
I built:
Dos+Windows 3.11 auto-install iso template (for vmware)
Reply 2 of 13, by myne
No worries.
Just let me know it works 😀
I built:
Reply 3 of 13, by Pierre32
I'm not sure when - but I will test this. Love your work!
Reply 4 of 13, by flynnsbit
I mostly got through everything just fine.
Tested Dos 6.22 + Win3.11 for workgroups
I had a section of the install that unmounted the cd and just booted to dos with only smartdrv installed, remounted in VMware player and rebooted and it continued on its merry way. I think this was in between the dos and win install.
Because I chose to use SVGA and W311FW the login screen would cause the graphics corruption noted in the notes. I did at least figure out if you go change the IRQ for the AMD network card it will allow a graceful boot with SVGA + Network. That helped a lot and the only think that will bug out the screen is dos prompt.
Reply 5 of 13, by myne
What irq did you use?
It's set to.... 9? Or 11?in the network inf
Might need to test it with your setting
It's supposed to unmount the CD but it's supposed to continue... Hmm
I built:
Reply 6 of 13, by flynnsbit
myne wrote on 2024-04-15, 21:38:
What irq did you use? It's set to.... 9? Or 11?in the network inf Might need to test it with your setting […]
This is what I ended up on and everything seems to be stable, dns etc works and no weirdness with login prompt. Everything seems pretty good if you stay away from the dos prompt.
Reply 7 of 13, by myne
If you're comfortable editing infs, I'd be curious if it works better at to that to start with.
Just search for vmware in the network.inf
I won't be able to access a real computer for at least a few days
I built:
Reply 8 of 13, by flynnsbit
myne wrote on 2024-04-15, 21:56:
Yeah sure, I'll give it a try later.
Reply 9 of 13, by myne
Cheers. I know I said no support, but I do want it to work.
I'm kinda hoping people will see the inf changes and add more hardware/patches etc. Or maybe even fix some of the gaps in the bats. I don't really like the invalid media type error, but it's all I could do that worked.
I left notes in the tricky parts of the infs.
The basic "slipstreamed" template with TCP, is, I think, a good foundation.
I built:
Reply 10 of 13, by elszgensa
Got linked here from that other thread. Haven't actually tested this template yet, but I noticed that it attempts to integrate the TCP/IP-32 stack (for "Windows for Workgroups 3.11") with what keeps being called just plain "Windows 3.11" (no "for Workgroups"). Both of those exist, but are different things - yet people keep confusing them, and I suspect this may have happened here, too. flynnsbit [technically deviated from the instructions and] had success using it with WfW; no surprise there since that's the intended platform. Can anyone confirm whether or not this also works with the non-Workgroups version?
Reply 11 of 13, by myne
It only takes a few minutes to build a iso and test in vmware.
The install is literally under 5 mins.
I don't think there were substantial differences so I expect it would work.
I built:
Reply 12 of 13, by elszgensa
myne wrote on 2024-12-10, 12:36:
I read that as "I dunno lol go figure shit out for yourself", which coming from the code's author isn't a good sign, then wasted a good 40 minutes doing just that. My findings:
The modified infs replacing the stock ones are clearly based on Windows for Workgroups 3.11, not Windows 3.11. Let's try it anyways.
The whole process indeed relies heavily on VMware's behavioral quirks. VMware doesn't work on my system, so I used QEMU instead and had to fiddle some things (manually change boot order at some points, sometimes manually reboot, stuff like that). That's out of scope for the template though, so - fair enough. I eventually worked my way past all of that.
A disc made from WfW floppies worked, but Windows 3.11 refused to install at all. "The version of setup.inf is not valid for this, yada yada...", soon followed by "The file setup.inf is damaged." Obviously this also means no TCP/IP-32, which, well, at least answers my initial question. Still unsure whether the TCP stack would install when doing it manually, but that's for another day (and thread). Doubt it though.
TL;DR: 100% gotta use Windows for Workgroups for this, not "vanilla" Windows, despite of what the instructions say.
Reply 13 of 13, by myne
Oh snarky. See title and point 8 and 9.
The 3.1 infs can probably be modified with the additions I made. It's commented.
But it's not something I'm interested in pursuing.
I built:
