First post, by willow
I have a problem with this game and dgvoodoo 2 last version on windows 11
The game works but quicktime video are not visible.
the sound works but no image of quicktime video.
If I turn on gdi in system hooks, display become black during video and works after the end of video.
Reply 1 of 7, by Dege
Indeed, thanks!
I fixed it. But plz keep in mind that QuickTime only tolerates an environment with unspecified scaling mode + unforced resolution.
Reply 2 of 7, by willow
Dege wrote on 2024-04-06, 16:58:
Indeed, thanks!
Thanks.
I have forgotten but I had find any workaround using this patch who do
Thank you for addressing the issue. I forgot to mention it here, but in the meantime, I found a workaround by using this patch ( https://community.pcgamingwiki.com/files/file … ed-quicktime-4/ ) that decouples QuickTime and ddraw. It works well even when replacing the ddraw.dll of this patch with that of dgvoodoo 2. It's even better if it works natively now.
Reply 3 of 7, by willow
Dege what versions of quicktime have you used ?
I have tried with gdi hook, video is displayed but it's not smooth. I have tired qtlite 4.1 and dgvoodoo 2 wip95_1.
Reply 4 of 7, by Dege
6.5.1, according to the QT player "about" menu. (2004)
Btw, no need for GDI hooking, as QT uses DDraw to render the video. At least the version I have. The bug wasn't tightly QT-related anyway. I also didn't experience lagginess or sg.
Reply 5 of 7, by willow
Dege wrote on 2024-04-10, 16:53:
Without gdi hooking, video is not displayed on my PC.
Reply 6 of 7, by Dege
Then you must have a different version of QT, or I don't know.
I already had QT installed, and did nothing but install the game, didn't apply any patch but fixed the DDraw bug and everything just worked.
Reply 7 of 7, by willow
Dege wrote on 2024-04-10, 21:28:
OK..
I have french version. I expect that the differences don't come from this version.
