Reply 800 of 1500, by Delphius
polpo wrote on 2024-03-28, 14:11:Delphius wrote on 2024-03-28, 03:23:Overall the balance is pretty great actually. It seems to work with in game controls that support it as well which is good. Excited to see what is coming up next for picogus and also the SB firmware. Looks like you might also be trying to get MPU running next to these / with other firmwares as well?
Next is to integrate USB mouse support (emulating serial mouse, but high speed so no lag like on a real serial mouse) that wbcbz7 contributed. Also yyzkevin is working on SBPro stereo DSP support. I don't have the skills to optimize Nuked-OPL3 enough to get OPL3 support, but emulating dual OPL2s is within the realm of possibility. This would allow SBPro 1.0 emulation. I also want to overhaul the USB joystick support to be able to expand the number of USB joysticks supported by PicoGUS. And of course there is the never ending quest to get GUS support working better on more chipsets. Thanks to someone here on Vogons I recently received a board with a problem chipset that I want to dive into.
Very exciting!
I also want to mention that Doom GUS is now working perfectly for me. I was able to get through a couple of levels with no problems, where as before it would freeze within about 30 seconds or so. Not sure if this changed with the last or previous patch.
