First post, by s997863
When I run older non-accelerated games on Windows-7 with a Geforce-960 card, they appear in wierd scrambled shades of black, white and gray. E.g.:
-Alpha Centauri.
-Jedi Knight (in software mode).
The only solution I found is DGVoodoo2, by copying the directx files into each game's exe folder (D3DImm.dll DDraw.dll D3D8.dll). This is inconvenient and causes other problems, i.e. I can no longer skip cutscenes in Alpha Centauri.
Has anyone experienced something like this and found a better solution?
Note: This is not like the Win7 "wierd colors in 8-bit games" problem that I get on Win7 with Radeon-7850: That problem easily gets fixed simply by leaving the Windows display properties menu open in the background. I never even have to try the various "ddraw compatibility" tools.
Reply 1 of 10, by BEEN_Nath_58
Each of the issue claims look like a fiction to me. Although I should admit I never saw anything as described on Windows 7, can you upload some screenshots or camera shots as to how they look.
About the other 8-bit issue you exaplained I probably misunderstood what you said or never have really used that workaround
Reply 2 of 10, by s997863
in-game screenshots (F9) create .pcx image files that show up normal, so I had to take photos:
-in-game color problem (only in software mode on an unmodified game).
-normal color in the windowed gui menu.
-normal color in-game (in software mode with DGvoodoo2, and also in 3d-accelerated mode)
-desktop-screenshot showing the DGvoodoo2 DLL files added in the game folder.
note:
I'm using nvidia graphics driver 471.96 (using nvslimmer tool to install only the driver and physx).
As for the other easier problem which causes odd colors on old games on Windows 7+, it's quite common and you can find links like this:
https://metropalaboy.wordpress.com/2015/01/09 … y-in-windows-7/
which mention solutions like killing the explorer.exe process, but this is not my problem on the Geforce card.
Reply 3 of 10, by ZellSF
The Geforce 960 launched the same year as Windows 10. 8 and 16 bit color support was already gone with Windows 8. Drivers probably just don't have good support for low color modes. Windows 10 is a better match for that hardware. It will at least attempt to emulate the low color modes.
Try downgrading drivers to 2015 versions, it might help.
Reply 4 of 10, by BEEN_Nath_58
I remembered what games had a similar issue. Frogger renders in B/W colour on post Windows 10 (1803+?).
The issue there was simple: a bugged d3dim.dll that has incomplete D3D Ramp mode.
What I am assuming is a corrupted d3dim.dll. You could try throwing in some d3dim.dll from the internet (since you are on Win7, try XP, 7 or Vista ones). It could help.
The other place where I have a black and white colour is in the D3D7 Immediate Mode demos (especially the globe demo). It is probably due to a driver bug. Maybe installing an older driver would help there, but I decided to stay with dgVoodoo2 or DDC. This problem started around the same time as your game problem, so driver is a pretty good culprit too.
Reply 5 of 10, by s997863
That did it, thanks!
Now using Nvidia driver 347.25.
As a bonus, this old driver is not even trying connect to the internet constantly like the newer versions do.
Reply 6 of 10, by eddman
Yea, if you want to stick to 7, you'd have to use an older driver.
I'm using driver 511.23 with a GTX 1060, and software mode looks fine on windows 10, so I suppose it got fixed with a later driver (haven't tried a newer one though).
Reply 7 of 10, by filipetolhuizen
Sorry for posting here after such a long time. I have finally found exactly what I've been going through. It started happening to me after upgrading to a GTX1660. Before that I was using a GTX460 with its latest supported drivers (391.35) and never had this issue. I was wondering which driver introduced this problem.
Reply 8 of 10, by BEEN_Nath_58
filipetolhuizen wrote on 2024-03-06, 04:17:
Btw I tested the game on Win11 with the lates 551 driver on 1050Ti and the problem doesn't exist. Probably they fried their old driver
Reply 9 of 10, by filipetolhuizen
s997863 wrote on 2023-09-04, 20:36:
Did you get a chance to find out which driver introduced this problem? With the GTX1660 I cannot go back that far, but I know the 391.35 driver still does not have this issue, as it was my driver of choice for my earlier GTX460.
Reply 10 of 10, by BEEN_Nath_58
filipetolhuizen wrote on 2024-03-07, 04:07:
Meanwhile I am trying to solve a white-texture issue in Direct3D apps, that seems to be affected in the391 drivers as well. I wonder if I should go as back as 2016
