dgVodooo 2.8.x and related WIP versions
Reply 101 of 108, by mitradis
UPD: in Vice City just need to disable the game frame limit (in game menu - video options). And ResX\Y=-1 if using GTAVC.WidescreenFix.
I suggest option for wrapper set affinity mask for game. Many games can work only on one or two cores (or 2 or 4 threads if HT is on).
For example i noticed from the game Blitzkrieg 2 (which not runs if not start with /affinity, because this game not see more 6 threads) if i start Blitzkrieg 2 with /affinity 1 game start but perfomance dramatically bad (because used 1\2 from one physical core). If /affinity 3 (1 + 2) that better but have stutters (because in reality game runs on 1 physical core). If /affinity F (1 + 2 + 4 + 8 = F) that much better (because game use 2 physical core). If /affinity 6 (2 + 4) game can (50% chance) not runs (something with threads between physical cores). F - best choice with HT.
Reply 102 of 108, by Glurak
So i tryed newest version with dungeon keeper D3DImm and DDraw. Games lunches. Intro Works fine menu works fine. But when you start a game. The game crashes.
Tryed Dungeon Keeper Gold with 3d3 patch
Deeper Dungeon and the Original with D3d Patch 😀
Reply 103 of 108, by Dege
I don't have a clue when I will have a new version, so I release the current state as a WIP (mostly fixes for problems I encountered):
WIP95
Changes compared to v2.82.3:
  • Fixing vertex clipping in D3D5 (regression) (Jet Moto)
  • Refactoring a lot of code in DDraw to implement resource sharing, to be compatible with MS DDraw (flashing screen in Colin McRae Rally 2)
  • Fixing DDraw clipped cursor problem (like with the config app of game Driver)
  • DD/D3D/8/9 frontend objects consumes less memory
  • Removing paletted texture format support of the GF9800 virtual card
  • Fixing a potential D3D8/9 swapchain leaking bug
  • Implementing some missing validation in D3D Draw methods
  • Fixing a clip coordinate space bug with sst origin lower left in Glide3+
  • Adding a new option DirectXExt\D3D12BoundsChecking (try it if you run into a GPU crash with D3D8/9)
http://dege.fw.hu/temp/dgVoodooWIP95.zip
http://dege.fw.hu/temp/dgVoodooWIP95_dbg.zip
Some explanation for DirectXExt\D3D12BoundsChecking: it's for cases when a D3D8/9 game accesses the vertex shader register array in out-of-bounds (OOB) way (buffer overrun).
It causes a GPU crash with dgVoodoo by default. The fix should not have an option, because D3D8/9 specs are clear about this case, so it should just be implemented in dgVoodoo.
However, according to my profiling, the implementation of bounds checking can cause 8-9% performance drop in certain cases wih certain games. That's a lot.
I cannot optimize it away, the (certain) needed D3D12 call is simply too expensive for extreme frequent usage, at least with my NV driver (did not tested other GPU's).
I only know of 2 games requiring this, The Witcher and Bound by Flame, so I decided to make this feature optional. Enable it if your GPU crashes with the D3D12 backend.
Reply 105 of 108, by Dege
I backported some fixes to the lates release, that's what 2.82.4 is about:
2.82.4
  • Fixing DDraw bugs (Konami Collector's Series: Castlevania & Contra, Blackstone Chronicles)
  • Workarounding a DDraw internal resource sharing problem
  • Fixing D3D5 vertex clipping (regression) (Jet Moto)
  • Fixing a D3D9 frontend bug (The Mark)
  • Fixing stenciling without a stencil plane in the D3D12 DX backend (Test Drive Unlimited 2)
  • Fixing potential descriptor corruption with sRGB textures in the D3D12 DX backend (Test Drive Unlimited 2)
  • Some minor refactoring in the DX frontent/backends
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_82_4.zip
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_82_4_dbg.zip
I also updated WIP95 with the latest fixes:
WIP95.1
http://dege.fw.hu/temp/dgVoodooWIP95_1.zip
http://dege.fw.hu/temp/dgVoodooWIP95_1_dbg.zip
Reply 106 of 108, by Dege
I release a new version with the latest fixes and also updated WIP95:
2.82.5 / WIP95.2
  • Fixing a bug in the ps.3.0 shader code translator (FFXIII crash)
  • Fixing a bug in the D3D12 backend related to compressed textures (FFXIII Lightning Returns crash)
  • Fixing a DX frontend bug causing missing cutscenes (Ascension to the Throne)
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_82_5.zip
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_82_5_dbg.zip
http://dege.fw.hu/temp/dgVoodooWIP95_2.zip
http://dege.fw.hu/temp/dgVoodooWIP95_2_dbg.zip
Reply 107 of 108, by Krolin
Dege wrote on 2024-03-19, 12:42:
Now CMR2 flashes really badly on 2.82.5 after changing in-game resolution (Options -> Graphics -> Advanced Graphics -> Display Mode). I'm using SilentPatchCMR2 and flashing only occurs when I set "Window=0" in SPCMR2.ini (I prefer forcing windowed mode through dgVoodoo because SilentPatch "Window=1" performs horribly).
Reply 108 of 108, by Dege
I cannot work on dgVoodoo these days, and I need some fresh air anyway, but I have some minor changes:
WIP95.3
  • Implementing a shortcoming in DD compression Blt (Europe 1400)
  • Implementing DD surface duplicating
  • Adding some new dbg layer error messages into DD Blt'ing
  • Adding bounds checking into generated VS cpu code
  • Improving API locking mechanism to avoid 'window message deadlock'
  • Minor refactoring here and there
  • Fixing a surface readback bug in the D3D11/12 backends (Virtua Fighter with forced resolution)
  • Fixing some problems related to PS2/3 input registers declared as centroid (Insane 2 with ingame MSAA)
  • Fixing a PS3 code generation problem (Borderlands with depth of field enabled)
http://dege.fw.hu/temp/dgVoodooWIP95_3.zip
http://dege.fw.hu/temp/dgVoodooWIP95_3_dbg.zip
*Notes:
  • dgVoodoo won't get into deadlock anymore with its own code in multithreaded window-message situations.
    However there are games (like TR4) that wait for DD/D3D without pumping the message queue, still causing
    deadlock/livelock. It cannot be resolved at wrapper side, it's only patching the game code that helps.
  • BL Depth of field is still wrong for me with D3D12 NV. The D3D compiler generates the same bytecode as dgVoodoo
    for the code in question, so I don't think my codegenerator is the culprit. The code gets converted into DXIL anyway,
    and no problem with AMD/Intel.
  • I upgraded compiler and now Defender detects some modules of dgVoodoo as Trojan (here we go again...).
    I might downgrade back to the old one.
I'll work on other reported problems. Slowly...
