First post, by st31276a
Edit: It is (almost) a PEAKTRON PLENTY PERI III - https://stason.org/TULARC/pc/io-cards/P-R/PEA … NTY-PERI-I.html
Does anybody perhaps know something about an XT multi function isa card made by Peaktron Electronics?
It has a floppy interface, two serial headers, a game port, a parallel port and a lithium battery holder.
It has a 765 chip with a couple of 74Ls… floppy driver chips, a soldered 8250 with a couple of serial drivers and receivers soldered, blank sockets for another set of these and some 74ls jobbies for the game port. I do not see an rtc chip anywhere, but there is a battery holder.
The mystery ic is a Peaktron PP2202, which looks like it decodes the addresses and activates the relevant subsection of the card.
It has a jumper block for configuration marked JP1 on the left and SW1 on the right with silk screened labels for what they do:
Blank
RTO or RTC1, cannot see properly
SER2
SER1
SER0
PT1
PT0
FDC1
FDC0
GAME
It looks like a jumper is placed when a function is disabled, as jumpers are on SER2, SER1 and FDC1. SER1 is not populated and it doesnt look like there is space on the board for SER2 and FDC1. I see only one printer port so do not know why PT1 is not jumpered.
This brings me to, where is the RTC? Could it be integrated into the mystery PP2202?
I found this card in the XT I discovered a while ago. It is a Juko ST-12 with a monochrome card in it, which also has a printer port and headers for a mouse port and a game port. It beeps on power up but does not look like it boots from the hard disk. Unfortunately I have no working monochrome monitors, I am looking out for a vga card that will work in it.
Meanwhile I am trying to figure out this mystery multi function card but cannot seem to find anything about it on retro web, stason or general searches. Any pointers will be appreciated.
