First post, by kant explain
I have to think ...
I have a chassis and a stack of Multibus boards. Tje chassis is for.an 80286, not sure if that predates the IBM PC/AT. But maybe.
(I have a IBM PC/AT also).
It's kimd of weird. Maybe I have early onset dimentia.
I have a Sony System 35 model 10, no keyboard.
I don't focus on old. Just groovy.
I have 2 Canon AS-100s. 1982.
Shoot my collection is looking kind of lamo.
Alright proceed -
Reply 2 of 18, by kant explain
I have a real nice Epson keyboard. I want to say it's for the oldest model.
Reply 3 of 18, by gca
My oldest two are a Phillips G7000 and a CPC464.
Reply 4 of 18, by Deano
The oldest not in storage, is a Pravetz 8m about 83-84 and a IBM/XT clone (not sure the age yet).
I have a ZX81 in storage, think that is probably the oldest (81-82)
Game dev since last century
Reply 5 of 18, by AppleSauce
I used to have a commodore 64 and that would have been my oldest but I sold it , so currently my oldest is an amiga 500 and 1200. Everything else is late 90s and after.
Reply 6 of 18, by Shponglefan
kant explain wrote on 2023-12-01, 01:36:
Is it one of these keyboards?
The attachment Epson Q503A keyboard.jpg is no longer available
This is the earliest Epson keyboard I have, a model Q503A. Has an 8-pin DIN connector.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 7 of 18, by shamino
About a year ago I bought an Atari 800XL. I didn't have an A8 back then but it got me interested ever since I learned about them in the 2000s.
I adapted a PSU for it and connected the SVideo signal, but the keyboard is unusable and needs to be replaced. It's a common problem with them. I haven't wanted to spend the money, so I haven't touched it since.
In the x86 realm my oldest are a couple of 486 boards and a 1993 Pentium board.
The ISA-only 486 has battery damage. I desoldered a bunch of parts but still have more to go. The parts I removed are stuck into a sheet of paper labeling where they go, but I got sidetracked. I hope I don't lose/confuse that mess before I finally get it back together. Some of those parts might also need to be replaced due to how contaminated they are from the battery.
The Pentium is 2nd oldest, I think it's the original Intel socket-4 board. It improves on the 486 by using a Dallas chip. I bought a replacement for that chip and I think the board works but haven't tested it thoroughly.
The VLB 486 board is newer than the Pentium and uses a coin cell battery. It was an eBay bargain a few months ago, it was having some flaky issues but after a lot of chip reseating, deOxiting, and some resoldering, I *think* it's all fixed and reliable now.
Everything else is socket 7+ so I'd class them as "modern" from a long range point of view. Things got more standardized pretty fast at that point.
Reply 8 of 18, by megatron-uk
Commodore PET 2000 series, so 1977-1978ish.
Have some TV game systems (IE Pong/Tennis) that possibly predate it, but that's my oldest fully working computer.
https://www.target-earth.net
Reply 9 of 18, by Vynix
That would be my Macintosh LC II from 1993-ish, followed by my P233 rig that I think is around 1994-95..
Reply 10 of 18, by ThinkpadIL
My oldest one is Sharp PC-1500 Pocket Computer, so 1981.
Reply 11 of 18, by chinny22
I suspect it'll be one of my 486's probably this one. Like many I threw out so much good stuff in the early 2000's 🙁
I accidently got a TCS9510 486 VLB PC
Reply 12 of 18, by NTG2001
Actual oldest computer I own would be two VIC-20s, but if we count based on the architecture, then it would be my TI-99/4A. Although the TI is one of the later revision beige ones with an Alps keyboard which is from around '82 or '83 I think. So, physically oldest would still be the VIC-20.
Reply 13 of 18, by SpectriaForce
Here's my oldest, an early 1998 theme pc:
The attachment 84734627272.jpg is no longer available
Guess what's inside 😀
Reply 14 of 18, by kant explain
Shponglefan wrote on 2023-12-02, 18:04:
Is it one of these keyboards? […]
Looks just like that. I paid too much on ebay. Figured I'd get a jumpstart on securimg an original E1 for myself. As I guess I was experiencing a hankering.
Reply 15 of 18, by HomeLate
My oldest is an IBM Display Writer from 1980, complete with display, dual floppy drives, keyboard and (massive) printer.
Second, more usable, Sinclair ZX81 and TI-99/4A... both released in 1981.
PC-'compatible' is an IBM 5150. It still works but it's hardly used.
Reply 16 of 18, by kant explain
Doesn't the Display Writer have an 8088?
Reply 17 of 18, by HomeLate
kant explain wrote on 2023-12-15, 13:26:
It had a 8086 and ran proprietary software (Display Write). I do believe you could run DOS or CP/M from floppy.
Reply 18 of 18, by RandomStranger
I don't have anything older than THIS. I also don't have any interest in owning anything older or anything that isn't IBM compatible.
