Old games that had CD Audio tracks?
Reply 100 of 110, by krcroft
Joseph_Joestar wrote on 2023-06-05, 04:04:
I think it would be beneficial to list the number of CD audio tracks that have been found on a particular disc during your grep search.
I didn't include it and don't plan to make this change, but agree it would be interesting.
The challenge is re-integrating the results with the groups' additions, removals, and improvements - all of which is a lot of manual work.
Would you be interested in making that adaptation to the grep statement and then manually re-layer the groups' modifications? (we could then drop my prior list and yours carry on as a rev2 improvement 👍)
That way, it would be easier to identify games which simply have 1-2 bonus tracks from the ones that actually use CD audio for in-game music playback. The latter usually have 5 or more CD audio tracks on the disc.
Games that use CDDA for spoken dialog often combine many sequences into a handful of tracks and simply seek within the track to play a particular sequence (as opposed to storing them as separate tracks). This is partly because tracks themselves waste some space, but more importantly because the redbook specification is limited to 99 audio tracks.
A couple examples:
- Jones in the Fast Lane (one CDDA track holds all spoken dialog)
- Stellar 7 (one CDDA track holds in-game music plus all spoken cut-scene dialog)
- Inca 1 CD edition (one CDDA track holds all spoken dialog and music)
- Inca 2 (One CDDA track holds all music. Note: some releases have different quality audio or might be improperly ripped) -- thanks Spikey
Reply 101 of 110, by Joseph_Joestar
krcroft wrote on 2023-06-05, 13:50:
Yup, that does seem to be the case. I'm not that good with Linux scripting, so this is all I could do about counting the number of audio tracks:
grep "AUDIO" *.cue -o | cut -d ':' -f 1 | uniq -c
When applied to Tomb Raider Gold, this results in the following output:
9 Tomb Raider Gold CD1.cue
3 Tomb Raider Gold CD2.cue
So the first disc contains 9 audio tracks while the second one has 3. Not ideal, but it gets the point across. Feel free to modify as you like.
Interesting. I imagine some "talkie" adventure games from that time may have used a similar approach.
Reply 102 of 110, by Spikey
Inca 2 definitely has all music in one large Redbook file too. Although some releases have different quality audio (or are improperly ripped), it seems.
Reply 103 of 110, by T-Squared
The Incredible Machine 2
This is the only DOS game that I can think of off the top of my head.
Reply 104 of 110, by MAZter
Moon Buggy (Rondomedia or Sprint Software releases)
Reply 105 of 110, by MAZter
Puzzle Castle (1996) 4 audio tracks
Reply 106 of 110, by HeroponRikiBestest
Joseph_Joestar wrote on 2023-06-06, 06:46:
Yup, that does seem to be the case. I'm not that good with Linux scripting, so this is all I could do about counting the number […]
If you still want this, I attached the results of running this on the current redump IBM pc set. I also attached the results for running it on the mac set, because why not.
Reply 107 of 110, by Joseph_Joestar
HeroponRikiBestest wrote on 2024-09-13, 21:15:
Thanks!
I think this makes a very good starting point. The final list would still need to be curated by hand, to exclude games which ship bonus tracks on the disc but actually use MIDI music during gameplay. Still, knowing how many audio tracks are on each game disc should make this process a bit easier.
Reply 108 of 110, by Spikey
Joseph_Joestar wrote on 2024-09-14, 05:09:
Thanks!
Yeah, I'd say identifying discs that have audio tracks versus those that do not is a great starting point!
Reply 109 of 110, by ludicrous_peridot
I didn't include it and don't plan to make this change, but agree it would be interesting. The challenge is re-integrating the r […]
A couple examples:
Not sure if this has been mentioned, but Deus by Silmarils uses CDDA for digital speech. There's one music trek and then one per each characters' for their spoken phrases. I have only digital reissue, so can't give much detail.
Also, again, pardon if has been mentioned Whizz has audio CD music.
GA-G41M-Combo G41/ICH7 - Core 2 Quad Q9550 - DDR3 1033 - Radeon RX570 - YMF744 (Cobra) - X3MB (Buran)
Beetle/M/i815+ICH2 - Celeron 566Mhz - Opti 924 (Typhoon Media)
Reply 110 of 110, by APOPAP
I am not sure,but I think the CDROM version of Jurassic Park had Cd-rom audio tracks.
