Reply 100 of 167, by B24Fox
- Member
@bloodem
Could you give your 1400 Thunderbird a short run in Prime95 (in place large FFT's), and measure the 5V rail with a multimeter?
I find it really odd how Segotep rated this cheaper model, with a higher output on the 5v+3.3v rails 🤔 I'm very curious how these two models would fair against each other.
_________
Much later EDIT:
For only 15euro more, I just bought the "Segotep ATX-500WH".
I just finished testing it in the exact same circumstances, with the GF3Ti500 GPU installed:
The Segotep ATX-500WH delivers exactly 0.1V more than the Segotep ATX-500W12 , and the +5V ATX wires aren't hot any more, and it also seems to have an extra transformer inside.
