First post, by Joseph_Joestar
- l33t++
I recently got this ATi Radeon X800GTO card (PCIe) and I've started building an LGA775 rig for it. The plan is to get a pretty overpowered Win98 system while also dual booting to WinXP. Here are the current specs:
- Core 2 Duo E6750 (2.66 GHz, Conroe)
- Foxconn P35AX-S motherboard
- 4 GB DDR2 (2x2 GB with dual channel enabled)
- ATi Radeon X800GTO
- Audigy2 ZS
- Kingston 120GB SSD (Windows 98SE)
- Crucial 250GB SSD (WinXP+SP3)
- Seasonic S12 III 650W PSU
- Nec 3.5" floppy drive
The system is working reasonably well so far, but I did notice that performance under Win98SE is much lower than under WinXP. This gave me flashbacks about the dreaded VIA AGP microcode bug, but that can't be happening here, right? That said, I am using Catalyst 6.2 under Win98 and Catalyst 7.11 under WinXP, but I doubt the driver version can make that much of a difference. One thing that does come to mind is that there are no official Win9x drivers for this motherboard, so that could theoretically impact the performance, but I've seen other people use PCIe cards under such conditions (including Phil in this video) and there didn't seem to be any issues. Here are some of my benchmarks:
Win98SE
- Quake2 640x480 software - 183.7
- Quake2 1024x768x32 OpenGL - 364.1
- Quake3 1024x768x32 OpenGL - 344.5 FPS
- Drakan 1024x768x32 Direct3D - 231.4
- 3DMark 2001SE - 25004
WinXP
- Quake2 640x480 software - 252.3
- Quake2 1024x768x32 OpenGL - 951.7
- Quake3 1024x768x32 OpenGL - 533.2
- Drakan 1024x768x32 Direct3D - 326.4
- 3DMark 2001SE - 30858
As you can see, there's quite a bit of difference between the two operating systems. Has anyone else noticed something similar?
P.S.
Is there a way to get USB 2.0 drivers under Win98SE on this motherboard? I think it's using the Intel P35 Bear Lake chipset.
