First post, by original_meusli
Hello,
I have two PC's that I want to connect to two midi devices, I have a working setup ATM but it is a real headscratcher every time I want to swap over the devices. I want to make this as simple as possible so I am looking to find something that can take two “midi in” connections and output to two Midi devices. I am thinking a 2 in 1 midi merge into a Dore midi passthrough device to the midi boxes. Then a device that has audio connections to mix the Soundblaster and midi sounds, I am not sure what that will be yet, whether a mixer station or just a plain audio interface, what would you recommend?
Cheers
Meusli
