Reply 340 of 549, by jheronimus
- Oldbie
ychh0 wrote on 2023-05-10, 10:38:Hello […]
Hello
Thanks for the reply.
Could you let me know where the bios is? I have chip programmer for bios flashing and think worth trying.
As for video, I plan to use VLB video card and it does not matter if onboard video is not working.Thanks.
All the images are here. The folders already correspond to the chipset names, but more detailed descriptions are in the spreadsheet.
There's a snapshot here. It's five months old, but I don't think a lot has changed for OPTi chipsets since then.
I never did anything like that, but I did have a case where I needed to burn a 64KB MRBIOS image to a motherboard that expects a 128KB one. In that case you need to fill the extra 64KB with FFFFFs — look at the image OPTI50C in my folder as an example. Whether it needs to be in the beginning or the end in your case, I don't know — maybe someone else has successfully replaced a combo BIOS with a non-combo one.
BTW, could you please upload your current BIOS file here? I will submit it to The Retro Web. Seems to be a pretty uncommon board, so it's worth documenting.
