First post, by Xanxi
Hi there.
I have been looking for a long time for those boards which allow to expand the ISA bus of a computer to a secondary case with more slots, just like the IBM 5161 except for 16 bits wide bus.
I have now those boards with their 2 meters cable from Kontron, so-called ECIK-2001, but i have no documentation or software whatsoever.
Any one here experienced with these boards?
My project is to expand the ISA bus of my Amiga 4000 in a secondary case but i might use it for another computer.
Reply 1 of 5, by Horun
Nice ! Never played with them but had seen them before a few times.
This link may give some info: http://web.archive.org/web/20020822223849/htt … exp/ptrc_at.htm
If you look close they are the same adapters....
added: looks like 2011 was last time on their website with good info: http://web.archive.org/web/20101119120622/htt … sa/ptrc_at.html
but links to software does not work
opps maybe 2018 was their last reference: http://web.archive.org/web/20181010090356/htt … sa/ptrc_at.html
Good luck !
Reply 2 of 5, by Xanxi
Thanks for these links.
I badly need software, unless these boards work as passive adapters. I don't know if there is a software part with the IBM 5161 bus expansion.
Reply 3 of 5, by Horun
They have lots of .pdf's on their website but only found this for the PTRC
https://www.accesio.com/MANUALS/PTRC-AT%20THI … 0TO%20CHECK.PDF
added: also found this: http://analoginput.com/MANUALS/PTRC-AT%20INST … INSTRUCTION.PDF
Reply 4 of 5, by weedeewee
at first glance there doesn't seem to be any microcontroller on those cards requiring software for initialization so, I'm guessing those are pretty much plug in, attach cable & forget about it being there.
Do not ask Why !
Reply 5 of 5, by Xanxi
Thanks Horun, you are expert at diging out things, i couldn't find anything useful myself with Google.
Yes weedeewee, you are probably right as the above pdf don't seem to mention any software.
Now, i need to find a nice secondary case with a backplane.
