HIDman - USB to PS/2 converter (Open Source)
Reply 100 of 428, by florian3
rasteri wrote on 2023-01-07, 19:01:
I'm sure there must be connectors somewhere that fit it.
I haven't found one so far. According to the spec sheet linked in the kicad footprint it should be a Powerdynamics PDI-9R-5. But I haven't found a place that sells it. The only part I found that somewhat matches is EDAC 624-009-361-033, mouser has a few. But only the signal pins should fit, not the holes for the boardlock. It's also $5, more common ones are around $1.
I tried to replace the footprint in the kidcad project here. Just tried to squeeze it in by moving a few capacitors and traces.
Reply 101 of 428, by rasteri
florian3 wrote on 2023-01-08, 04:30:
Nice one. Feel free to submit a PR.
There is one other change I need to make to the AXP version, DTR needs to be routed to the MAX232 instead of TXD. This is required for reset detection.
I can fake it for existing boards (by spamming "M" for a few seconds after RTS goes high) but I'd prefer to do it the "proper" way.
Reply 102 of 428, by rasteri
Eivind wrote on 2023-01-07, 18:00:
Any new firmware updates...? 😬
Been busy testing graphics cards on the Vortex86EX 😀
But seriously yeah very soon, I'm still debugging the serial protocol but hopefully I'll get that finished in the next couple days.
Reply 103 of 428, by rasteri
OK with the latest commit the serial port should work, it's been tested with ctmouse and Windows 98. Movement is a little jerky under some circumstances, mainly because of the much lower data rate and DPI of serial mice. I'll have to implement some sort of DPI scaling and/or movement filtering, but it's very usable for now.
Also the LED does something now 😀 Green by default but yellow when it detects USB activity. The LED brightness could use some adjusting still.
@Eivind, I've added some more info to the HID debug output. Any chance you could log your Kova plugging in again for me?
Reply 104 of 428, by tabm0de
rasteri wrote on 2023-01-08, 23:21:
Aha you are emulating the serial mouse like a true ball mouse with dirt 😉
naa, nothing yet...
Reply 105 of 428, by rasteri
tabm0de wrote on 2023-01-09, 00:15:
Yeah haha even with the jerky movements it still feels much smoother in windows than any of the serial mice in my collection....
In DOOM there is noticeable jitter. It's still more than playable though.
Reply 106 of 428, by florian3
rasteri wrote on 2023-01-08, 13:36:
I tried the new software with my board and so far I couldn't get the serial mouse to work with my board. COMTEST.COM from ctmouse thinks a modem is connected.
Reply 107 of 428, by rasteri
florian3 wrote on 2023-01-11, 20:19:
What PC are you using? Do other serial mice work on it?
I've only tested it on a couple of PCs so far but I'll try some more this weekend.
Reply 108 of 428, by florian3
It's a Socket7 system, serial port on the board. The only serial mouse that I have works on that computer.
I'll have another look at the HIDman board that I built, maybe I messed something up. Can also try with a some other computers.
Reply 109 of 428, by rasteri
florian3 wrote on 2023-01-13, 14:57:
I've tried a bunch of computers of various ages, from an 8086-based Amstrad to a Quad-core Xeon, seems to work on them all. Although COMTEST detects a modem too.
Any chance you could get me an HID log dump of your Kova on the most recent firmware? EDIT : oops sorry I realised I already asked, there's no hurry.
Reply 110 of 428, by Eivind
rasteri wrote on 2023-01-17, 12:44:
Damn, I completely missed that last request of yours! 🙁
Sure thing, I'll do a round of testing and log dumping later tonight! 👍
TinyLlama 3
ITX-Llama motherboard
TinyLlama SBC
Reply 111 of 428, by florian3
I tried it on a 486 and I got the same behavior as on my other computer. Do you maybe have a binary of the software that I could try on my board? Not 100% sure about the toolchain that I'm using, got some ICE at some point..
Reply 112 of 428, by rasteri
florian3 wrote on 2023-01-17, 23:51:
Oh sure, attached.
Just had another thought- what type of serial cable are you using? It should be a plain old extension cable, not a null modem or anything like that
Reply 113 of 428, by Eivind
@rasteri: Attached a log dump of unplugging and reattaching the Kova+ using firmware compiled from commit f25808e.
TinyLlama 3
TinyLlama SBC
Reply 114 of 428, by florian3
rasteri wrote on 2023-01-18, 00:12:
Oh sure, attached.
Thanks, result is same as before.
The cable that I'm using should be a plain extension, at least my serial mouse connected through the extension works.
Reply 115 of 428, by serisman
serisman wrote on 2022-12-24, 01:00:
rasteri wrote on 2022-12-24, 00:41:
serisman wrote on 2022-12-23, 20:58:
Now I'm wondering if an HIDman-micro using the smaller CH559T (SSOP-20) is in order. 😀 (would need to modify the pin configuration a bit)
All the PS/2 stuff is bit-banged so the choice of pin is arbitrary, it should be very doable.
That said the SSOP package isn't really much smaller than the QFP one...
Here's what I just came up with...
Drops support for the 2nd USB port, Serial mouse, RGB LED, and the extra (unused) KB/MS ports. But, should allow for a really small USB wireless KB/MS combo to PS/2 KB/MS.
I finally got some CH559T ICs and HIDman-micro (https://github.com/serisman/HIDman-mini/tree/ … Bs/HIDman-micro) PCBs delivered and had some time today to put one together.
Good news is that (after some code modifications) it works great!
A build with a combo PS/2 KB/MS port is size comparable to (or slightly smaller than) just the port itself on a standard PS/2 cable!
I'll submit a Pull Request to @rasteri's main repository for the code changes, but in the meanwhile feel free to use my fork: https://github.com/serisman/hidman
You'll need to modify the Makefile to set BOARD_TYPE = BOARD_MICRO and optionally BOARD_OPTIONS = OPT_SWAP_KBD_MSC (make it easier to direct solder a combo port), or just use this command line:
make BOARD_TYPE=BOARD_MICRO clean flash
Reply 116 of 428, by tabm0de
serisman wrote on 2023-01-21, 03:46:
I finally got some CH559T ICs and HIDman-micro (https://github.com/serisman/HIDman-mini/tree/ … Bs/HIDman-micro) PCBs delivered […]
Damn thats nice, size way it is as big it could have been back in the days but probably with rf signal 😀
naa, nothing yet...
Reply 117 of 428, by rasteri
Awesome! I'll merge all the PRs when I get some time.
Great work.
Reply 118 of 428, by tabm0de
You should make a mini serial version 😉
naa, nothing yet...
Reply 119 of 428, by rasteri
tabm0de wrote on 2023-01-23, 11:59:
Powering a keyboard from the serial port would be non-trivial.
