First post, by Kahenraz
I got a great deal on an Intel Xeon E-2278G from eBay, but the difference between the photos in the listing and the item I received was striking. The item was listed as used, with photos of good condition processors in trays, which is what I thought I was a getting. The item I actually received however, was scratched, dinged, missing a small chunk of the PCB on either side, and significant damaged to the underside capacitors.
As a reminder, always inspection your item carefully, no matter what!
The attachment Screenshot_20221217-081302_eBay.jpg is no longer available
The attachment Screenshot_20221217-081306_eBay.jpg is no longer available
The attachment 20221205_180024.jpg is no longer available
The attachment 20221205_180044.jpg is no longer available
The attachment 20221205_180108.jpg is no longer available
Reply 1 of 6, by Kahenraz
Here are some close up of the capacitors.
The attachment 20221216_231316.jpg is no longer available
The attachment 20221216_231412.jpg is no longer available
Reply 2 of 6, by Kahenraz
I tried my usual method of making a small bubble of solder that extends across the width of the component to cover both sides, and then lifting the capacitor away once it had separated. However, I found the CPU to be a much too strong of a natural heatsink for this kind of casual work. Part of the issue was that the processor itself was a highly concentrated thermal mass, but also the ROHS solder binding the component to the PCB, which has a much higher melting point than traditional leaded solder. I switched to hot tweezers and the capacitors lifted away easily.
All three of the capacitors were the same physical size. Two of them measured 1uF, and the third closer to 0.5uF. I believe the last one was actually in error, as it was physically damaged, so I opted to use 1uF as a replacement for all three.
I then used a fine-pitched solder paste and hot air to attach the new capacitors. It was a struggle, again, due to the high thermal mass, but the solder eventually took and the components attached.
I plugged it into my motherboard and the system booted up perfectly. I've since put it through its paces with Prime95 and it appears to be stable. This is an expensive processor, so I'm glad that I was able to salvage it with this repair.
The attachment 20221217_005111_resize.jpg is no longer available
The attachment 20221217_005232_resize.jpg is no longer available
The attachment 20221217_005607_resize.jpg is no longer available
The attachment 20221217_010010.jpg is no longer available
Reply 3 of 6, by Kahenraz
I almost had a different crisis with the motherboard I ordered to go with it, also from eBay. See if any of you can spot what made this photo such a terrifying surprise when I opened the box.
The attachment 20221211_191208.jpg is no longer available
Reply 4 of 6, by Roman555
Kahenraz wrote on 2022-12-17, 13:35:
my guess
The CPU socket was not protected by a lid
P.S. I've read those little capacitors are difficult to re-solder. Usually a CPU works well without some of them.
Good job!
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 5 of 6, by Kahenraz
Roman555 wrote on 2022-12-17, 15:36:
my guess
Yup. Somehow it made it through shipping undamaged. Incredible.
Reply 6 of 6, by Kahenraz
Luckily I had bought some hot tweezers this past year, as I do encounter some very stubborn components on occasion where one would be useful. I have a very powerful Hakko iron, as well with high quality tips, but they just couldn't get the heat concentrated well enough to remove these capacitors. The hot tweezers removed them in seconds.
