First post, by fsmith2003
- Member
I have a Voodoo 3500 hooked up to a 2 port VGA switch. A Geforce256 build is also connected to the switch.
The problem I am trying to solve is an odd one. This configuration worked initially. I had both computers set at 1024x768 32-bit on the desktop. The next day I booted just the Voodoo PC and the resolution was now set at 16-bit 640x480 and I was unable to change it to anything else. I thought maybe there was a driver issue or something. I uninstalled then reinstalled to Voodoo driver and IT WORKED AGAIN!
...Unfortunately though, after the next reboot the exact same thing happened and it was back to 640x480. The weird part is, the Geforce has no issues whatsoever and maintains the 1024x768 resolution through every reboot.
The VGA switch is an Extron brand that is defiantly capable of handling higher resolutions and refresh rates.
What could be the issue with the Voodoo 3500 that keeps it from maintaining the set resolution? IS there an obvious setting that I am just overlooking here?
