Reply 80 of 109, by dataino.it
- Member
#: 72
Manufacturer/Identifier: GSH-286
Chipset: GST GOLD GS62C201 GS62C202
BIOS/Version: AMI DGS2-1402-101090-K0
#: 72
#: 73
Manufacturer/Identifier: ECS 286A PLUS
Chipset: ALi M1207 (286 Single Chip) [M1207]
BIOS/Version: AMI DAR2-1131-061390-K0 V1.0 061390
#74
Manufacturer/Identifier: VGA ACER
VGA integrated into ACER 915V (II) motherboard 80286
Chipset: Acer m3125
#: 75
Manufacturer/Identifier: Bullet 286 XT
Chipset:
BIOS/Version: NSSI dump
lgj1107 wrote on 2020-03-02, 07:07:ALR 286
Hi
I used these bios but pc locked with logon pass
For unlock this need user pass or supervisor pass for remove in bios settings
Can you share pass please
Br
Edit: logon pass disabled by cmos battery method.
But supervisor pass unknown
Edit 2 : supervisor password is "power" without ""
#76
Manufacturer/Identifier: SP/286-A+ version 003 (A.T.C. Artek Computer Systems)
Chipset: discrete Intel
BIOS/Version: Award v3.03
Seems to be a slightly different version/revision of this board : https://www.ultimateretro.net/en/motherboards/655 since J17 isn't present
Has battery damage. Currently gets stuck at post 17, sometimes 1f, once at C3.
edit : https://www.ultimateretro.net/en/motherboards/10193
thanks 😀
Do not ask Why !
#77
Manufacturer/Identifier: Vtech L286_2 ( came from a Laser computer)
Chipset: TACT8220(1/2/3/4/5)
BIOS: AMI
untested, varta battery damage.
edit : https://www.ultimateretro.net/en/motherboards/10194
thanks 😀
Do not ask Why !
#: 78
Manufacturer/Identifier: Plantron
Chipset: Headland GC101A-PC GC113-PC G2 GC102-PC
BIOS/Version:
#: 79
Manufacturer/Identifier: Wyse WY-2108
Chipset: Unknown
BIOS/Version: Phoenix Technologies Ltd. V2.74
System BIOS setup disk attached.
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
#80
Manufacturer/Identifier: ASK CAT102
Chipset: Headland GC101A/HT102B
BIOS/Version:
#: 80
Manufacturer/Identifier: Unknown 286M
Chipset: TI TACT8230
BIOS/Version: AMI
BIOS ID: D286-1430-040990
#: 81
Manufacturer/Identifier: Schneider Tower PC AT 286 "System 240"
Chipset: G2 GC102
BIOS/Version: Phoenix 80286 ROM BIOS PLUS Version 3.10 00
BIOS ID: 80286 AT BIOS V2.01A
Note: System + VGA BIOS
#: 82
Chipset: SOLUTIONS L1A4436 L1A4438 L1A4736
BIOS/Version:
BIOS ID:
https://theretroweb.com/motherboards/s/unknown-neat-286
#: 83
Manufacturer/Identifier: TOPTEK
Chipset: VLSI VL82C100, VL82C101, VL82C102, VL82C103, VL82C104
BIOS/Version: AMI
BIOS ID: D286-1295-091589-K0
#: 84
Manufacturer/Identifier: PEAKTRON COMPUTER, INC.
PA386SX-SMT-16/20/25
PA286-SMT-12/16/20/25
Chipset: SA1 PE168AK, SIS 85C206
BIOS/Version: AMI
BIOS ID: D286-6182-101590-K8
Jumpers settings: https://theretroweb.com/motherboards/s/peaktr … -pa-386sx-16-20
https://stason.org/TULARC/pc/motherboards/P/P … T-16-20-25.html
Tronix wrote on 2022-09-09, 09:43:#: 84 Manufacturer/Identifier: PEAKTRON COMPUTER, INC. PA386SX-SMT-16/20/25 PA286-SMT-12/16/20/25 Chipset: SA1 PE168AK, SIS 85C […]
#: 84
BIOS/Version: AMI
BIOS ID: D286-6182-101590-K8sis.jpg
Jumpers settings: https://stason.org/TULARC/pc/motherboards/P/P … T-16-20-25.html
Do you have a picture without a watermark? Unless this is actually your board and you have the rights to it?
#: 85
Manufacturer/Identifier: M-216A ver1.1
Chipset: PC Chips CHIP 2 TC14L100F2052
BIOS/Version: AMI
BIOS ID: 30-0100-ZZ1437-00101111-070791-PC CHIPS
Jumpers settings: https://theretroweb.com/motherboards/s/pcchips-m216a
https://stason.org/TULARC/pc/motherboards/I/I … 386-M-216A.html
Note1 : JP16 must be set to 1-2 for 286, not 2-3 as specified in jumpers settings;
Note2: MB not start with 512Kb RAM in BANK0 with any jumpers combination; Managed to run only with BANK0 and BANK1 ;
#: 86
Manufacturer/Identifier: UNIDENTIFIED / ZERO WAIT HAM/12-TI
Chipset: TACT82301BPB, TACT82302BPB, TACT82303EPB
BIOS/Version: AMI
BIOS ID: D286-1112-040990-K8
Jumpers settings: https://theretroweb.com/motherboards/s/aquari … -wait-ham-12-ti
https://stason.org/TULARC/pc/motherboards/U/U … -HAM-12-TI.html
#: 87
Manufacturer/Identifier: Zenith CPU/Memory Board 85-3261-01 052086
Chipset:
BIOS/Version:
BIOS ID:
Manufacturer/Identifier: Delta 065-3.3-0789
Chipset: TACT82000
BIOS: Award
Motherboard: Delta 065-3.3-0789
