Same Card?
First post, by Soap
They look the same component wise, seem to have same markings but are they the same?
I lost an Auction as I wasn't prepared to go past £45, the card was described as "Audican 32 Plus YMF718-S". Anyway I offered another seller £20 including delivery for what appeared to be the same card described as "Yamaha OPL YMF719B-S LWHA151A00 A151-A00" and they accepted.
Are both these cards Audican 32 Plus cards?
Reply 1 of 7, by Con 2 botones
They do install with the same driver (I use the one from P.C.L site) .
I own both.
Reply 2 of 7, by The Serpent Rider
Audican cards don't have second oscillator soldered AFAIK. Other than that, it's a generic PCB design for a bunch of Yamaha 718/719 OEM cards.
Reply 3 of 7, by Soap
The Serpent Rider wrote on 2022-08-29, 19:07:
Oscillators being the two silver things to the far left? If so the card advertised as Audician was not an Audician?
Reply 4 of 7, by Tiido
The Audicians were all still Labway made cards, and there are many flavors according to the box, depending on what was ticked on the side 🤣.
When the YMF71x card is mithout second crystal, the 32 and 48KHz sample rates are both wrong (way too high pitched) as 33.8688MHz crystal the card absolutely requires is also made to feed the secondary 24.576MHz crystal, leading to this wrong pitch. The cards should always have both crystals installed, but there are plenty that only have one of them.
Reply 5 of 7, by Soap
Tiido wrote on 2022-08-29, 20:09:
So the card on the first picture that has two crystals? Looking at the picture does it appear to be good selection?
Reply 6 of 7, by Tiido
Yes, it does, and it is the typical YMF71x card. Nothing awesome but it does its job (I made a YMF71x card that gets all out the chip but there's some time until it becomes available again).
Reply 7 of 7, by Soap
Tiido wrote on 2022-08-29, 21:22:
I'm just truly fed up with the Creative mine field I mean find the right version of each model, oh and the prices too, £20 for this seemed too good be true so probably is moment.
Will be interesting stick a wave table on this and compare to my AWE 64 gold on another system.
Thanks for help.
