First post, by ras2a
Hi guys,
I've been researching YT, and, more specifically, PhilsComputerLab YT channel (which is absolutely excellent) for advice on what the best options/builds are to run:
1st build) A good range of DOS / Win9x games with good compatibility, performance and sound support for both DOS & Win (considering just installing Win9x for this build and using 'DOS mode' for the DOS games). I'm looking for a single build here.
2nd build) A good range of WinXP games with good/great performance
I've concluded that the HP Thin Clients: T610/T610 Plus/T5720 etc could possibly be suitable for the above 'builds' to run games at decent performance and also that I may be able to get away without going for a dedicated build
Questions:
1) What do you lovely people think of the above Thin Clients and are they suitably powerful enough for the above jobs or if I should be looking at alternatives or dedicated full 'period' PC builds?
2) Are the above devices ok in terms of driver support under the listed OS'es and will there be any video/sound issues?
Other thoughts:
I could, alternatively, use one of the above Thin Clients as a Win10 / DOSBox build (as per another of Phil's fantastic videos) with MUNT emulation etc, which could be great? That still wouldn't cover off the Win9x requirements, however.
Thanks ever so much for any advice guys - very much appreciated
-ras
