Reply 120 of 223, by Sphere478
- l33t++
CalamityLime wrote on 2022-06-26, 16:14:Kahenraz wrote on 2022-06-26, 16:06:Maybe I'm misunderstanding. Aren't the regulators on the PCB going to be working in tandem with the motherboard to provide any additionally needed power? It sounds like they are going to be replacing it entirely, if they are being taxed so much.
You could probably use the motherboard vrm to make the voltage for the IO but as far as I know we're looking to replace the motherboard core vrm with out own one. It's easier to replace the on board one than to work with it since the power draw will always favour the higher voltage and the load would be uneven, which could upset the regulators and make them produce more heat than they need to. An easy way of making two regulators work together would be to use some small value resistors on the out, something like 0.1 ohms, just to help them out.
Not much need to replace the v I/O we just let it pass through the interposer. Vcc2 (vCore) is what we worry about.
It is possible to regulate down from the 3.3v of the motherboard. In theory this would create less heat for the individual regulators but it’s also probably a bad idea because it will also increase the load on the motherboard significantly not only adding the processor heat envelope to the power required, but also the new regulators, causing a net increase in power draw.
It’s best to power it with switching style.
It worked on 486 setups, but prob bad idea to do on socket 5/7.
Yeah, like I said, the way we came up with is better. You are gonna need a power plug anyway. May as well put a pre made one on the power cord.
Btw: pentiumspeed brought up some good points about needing that ground we removed. I’m gonna have to update the device to re introduce the ground wire.
