First post, by Byrd
Hi all,
I've a revision 1.0 Epox EP58MCP3C-M motherboard, running an AMD K6-2 500 CPU.
According to documentation it tops out at 5.0X multiplier and 100FSB - there is suggestion (but couldn't find the info) the board supports an undocumented 5.5X multiplier and 112FSB, does anyone know the right config?
The other option to overclock is 95FSB and 6X multiplier (setting 2X for the K6-2 puts it to 6X) @ 570Mhz, however it appears this does reduce performance more than you'd think.
Thanks
JB
