Reply 42880 of 56007, by GigAHerZ
- Oldbie
dr.ido wrote on 2022-03-01, 10:52:Bit of a stretch to assume that any random seller of hardware in Russia supports Putiin.
That's an assumption you made, not something that was implied by HanJammer.
Maybe one does not want to send money into Russia, because then it could be used to buy bread inside Russia, which means through taxes contributing to the Russian government actions. Nothing to do with actual support of Putin by the seller.
So what HanJammer has expressed is totally understandable and valid stand.
But let's try to keep politics away from this forum. 😀 I really like that this forum is quite clean of that stuff. 😀
