Pisomojado wrote:On the official website here
http://prdownloads.sourceforge.net/dosbox/DOS … mg.zip?download
Mac users are instructed to download a disk image.
Ah 🙁 My fault. I wasn't aware that the Mac OSX version is listed among the official downloads. I thought it was something that rhonie had put up on a private web-site somewhere.
Pisomojado wrote:Inside are two folders labeled INTeL and PowerPC.  Each contains an item called DOSBox Preferences.
I have to ask rhonie why 2 preferences files are needed... It seems unnecessary to me.
Pisomojado wrote:As to what to do with this, I have four sets of instructions to work with: […]
First, Rhoenie's:
<snip>
4) Unlike other Mac software DOSBox doesn't create a preferences file on its own: you have to do that! The reason is simple: there is no proper way inside the DOSbox application to set up all the different things and save them.
Well..... That is technically not true. There is no fancy graphical interface for setting and changing preferences, but there certainly is commands to set things up they way you want them (config -set name-of-config-section settings-name=settings-value) ), and a command to save them (config -writeconf "/path/to/preferences/file"). Incidentially, this is what front-ends are for: Provides a graphical interface - a front-end - for editing that pesky preferences file.
Pisomojado wrote:On the other hand, I have your instructions, which are the official installation guide:
😅 Official, and official.... Someone noticed that I was pretty active on the forum, and seemed to know what I was talking about, so I was asked if I was interested in help moderating the forum here. I guess that makes the stuff I write somewhat official, but I am only human (more on that later).
Pisomojado wrote:   2. Create the preferences file:
      Z:>Z:\>config -writeconf "/Users/your-login-name/Library/Preferences/DOSBox Preferences"
<big snip>
I tried to do as you requested, obeying your instructions with the goal of creating a new DOSBox Preferences file to compare to the one which came packaged in the disk image.  Unfortunately, I made some mistake.  I repeatedly got this error: "Illegal command: Z:\-writeconf."
As I said - I am only human. There is an error in the guide. Leave out the double Z:\>. That is the prompt that DOSBox writes. The command should read:
Pisomojado - didn't it strike you a bit odd with the double Z:\> stuff? I am not blaming you for trying to follow the guide to the letter, but don't be afraid to use your critical sense too. Also, there should be a Read-Me file included with your DOSBox-image, with documentation and examples for all the internal DOSBox commands, including config.
Pisomojado wrote:And, lastly, the instructions located in the MAC OSX Pictorial guide:
Part 3: Using .conf Files
In order to save time lets create a DosBox.conf file that will automatically mount your C: drive when  […]
In order to save time lets create a DosBox.conf file that will automatically mount your C: drive when you start DosBox.
Switch to your DosBox window and type
Code:
config -writeconf DosBox.conf
exactly as is, no substituting this time.
Go back to your DOSBox folder and look for the new file DosBox.conf <snip>
/Applications/DOSBox/DosBox.app/Contents/MacOS/DosBox -conf /Applicactions/DOSBox/bak.conf
You have run into one of the blessings - and curses - of Open Source Software: We love flexibility, we love freedom to put our files wherever we want, name them any way we want, and we accept that it makes it impossible to give short, definitive answers.
As rhonie pointed out earlier when you asked where to put your DOSBox stuff - in the Documents or the Applications folder - he answer was: It is all up to you. It depends on how you feel it should be.
The guy who wrote the pictorial seems to prefer to put the preferences file in /Applicactions/DOSBox/ - that's all. rhonie thinks they should go in ~/Library/Preferences. I would put it inside the DOS\MyGame folder, so I could have a preferences file for each of my games - each file with its own commands to automatically mount drives, and execute the game.
We each have our preferences(!) as to where we think files should go - and it makes the guides differ. For now, I recommend that you go with rhonie's approach: One "DOSBox Preferences" file in the ~/Library/Preferences folder. Later, when you get more experience with operating DOSBox, you can try other tactics - including using a front-end to manage multiple preferences / configs / profiles files for you HUGE collection of DOS-games.
Pisomojado wrote:I tried to do as you requested, obeying your instructions with the goal of creating a new DOSBox Preferences file to compare to the one which came packaged in the disk image.  Unfortunately, I made some mistake.  I repeatedly got this error: "Illegal command: Z:\-writeconf."
What are your thoughts?
Drop the Z:\> and try again.
_________________
