Most recent platform for Baby AT motherboards?
First post, by Lylat1an
I'd like to upgrade the hardware in my Retro Rig if possible, the best I could find back when I built it was a Super Socket 7 system with a Baby AT motherboard.
I want to keep the case, which is not compatible with ATX, thus I believe I'm limited to Baby AT.
Were there any better platforms made in that form factor?
Reply 1 of 39, by Repo Man11
There were baby AT boards that were Slot 1 and Socket 370. I once had one that, with the use of a Lin Lin adapter, supported a 1.4 GHz Tualatin Celeron. AFAIK, Pentium 3 was the fastest ever supported in a baby AT motherboard.
This 440 BX Socket 370 Baby AT board is likely the best ever made in that form factor. https://www.anandtech.com/show/316
Reply 2 of 39, by cyclone3d
If you really wanted, you could probably go up to at least Pentium 4 if you use a backplane and SBC.. maybe even higher. But it wouldn't be much of a retro rig then.
As for upgrading at all, what is the current hardware?
Do you use it for DOS as well as Windows? this is mainly for knowing if it would be better to have at least one ISA slot for a soundcard.
What games and applications do you want to run that are not running fast enough on your current setup?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 39, by rmay635703
M812lmr was an AT style socket A motherboard
Should work with most any Duron
Reply 4 of 39, by Lylat1an
cyclone3d wrote on 2021-12-29, 18:05:
If you really wanted, you could probably go up to at least Pentium 4 if you use a backplane and SBC.. maybe even higher. But it […]
Well, the case is from an IBM PC XT. I haven't seen any backplane SBCs that look short enough to fit in one of those.
Motherboard: ASUS P5-99B
CPU: 500MHz AMD K6-2
Memory: 512MB
Video: Nvidia GeForce 6200 PCI.
Audio: Sound Blaster 16 with wavetable board.
Mouse: Logitech C7 bus mouse with 8-bit ISA card.
As for applications, I just want to play old DOS and Windows 9x games that haven't been ported to modern Windows.
Currently I suspect that the power supply is holding me back. (It's only a 200w AT model) I found that Athena makes 400w ones, but I question how reliable they may be.
Reply 5 of 39, by gex85
Jetway 849BS is another Socket A/462 Baby AT board.
It supports 133 MHz FSB CPUs (Athlon XP) and has an AGP slot, so I'd prefer it over the M812LMR.
My retro computers
Reply 6 of 39, by Repo Man11
Today I learned that there were a couple of Socket A baby AT motherboards made! Someone like Phil should do a comparison of the last of the baby AT motherboards made to declare a winner for the fastest ever baby AT board. A good contender for the title: http://www.motherboard.cz/mb/jetway/849BS.htm
Edit: I also didn't know that there were baby AT boards that had no ISA slots!
Reply 7 of 39, by Repo Man11
Op, your motherboard has an ATX power supply connector; have you considered using one? Much easier to get a good quality power supply that way, and all you lose is the reset button (since it becomes your power on button).
Reply 8 of 39, by cyclone3d
Ok, for the power supply, since it is an XT case, I would swap out the innards with a good ATX power supply and use an ATX to AT adapter unless your AT style board has ATX connectors.. most of the newer ones do.
Slot-1/Socket 370 is probably going to be your best best. Just need to look for something with AGP and at least 1 ISA slot and then worry about the chipset after that.
YMF7x4 Guide
Reply 9 of 39, by cyclone3d
gex85 wrote on 2021-12-29, 18:35:
But it doesn't have an ISA slot.
YMF7x4 Guide
Reply 10 of 39, by Lylat1an
Repo Man11 wrote on 2021-12-29, 18:40:
I have, but I think I need a -5v line for my ISA cards. I could use a Voltage Blaster, but I would need a 3rd slot for it.
Reply 11 of 39, by BitWrangler
Back in the early oughts, when my IBM Portable PC was worth about $40 if you found an enthusiast or $1.50 in scrap, I was contemplating stripping it out and installing an AT board. This was when they had still been produced in the living memory of a goldfish. The conclusion I came to at that time was that a 440BX board with a Tualatin was likely the best I could do. I have parts now I could maybe do it with, but I'm unlikely to find another IBM Portable at $40 or below.
Reply 12 of 39, by cyclone3d
Lylat1an wrote on 2021-12-29, 18:47:
There are very few cards that need -5v See here:
ISA Cards & Devices Requiring -5V
Even if you do have a card that needs -5v, you can always use an ATX to AT adapter that adds it:
https://www.ebay.com/itm/174646835381
There used to be a person on eBay that sold pre-made cables that added the -5v but they stopped a couple years ago now. The one linked above is a newer design but more expensive.
YMF7x4 Guide
Reply 13 of 39, by Lylat1an
cyclone3d wrote on 2021-12-29, 20:06:
There are very few cards that need -5v See here: ISA Cards & Devices Requiring -5V […]
I didn't see either of my cards on that list. But if they do need -5v, would they be damaged if I run them without it?
Reply 14 of 39, by cyclone3d
Lylat1an wrote on 2021-12-29, 20:57:
Nope, they just won't work properly.
YMF7x4 Guide
Reply 15 of 39, by SpectriaForce
cyclone3d wrote on 2021-12-29, 18:44:
In case of using an ATX power supply without an ATX to AT adapter, the OP would have to connect the original power switch of the IBM PC XT power supply with some wires to the motherboard power switch header to act as a soft power switch, otherwise OP can't turn on the ATX power supply to power the motherboard (at least if OP wants to avoid using another button / switch).
Reply 16 of 39, by wiretap
I made a PCB for that.
Re: New solutions to the ATX -5V problem
My Github
Circuit Board Repair Manuals
Reply 17 of 39, by imi
the newest... SBC and backplane, there's backplanes in BabyAT format with keyboard connector, and SBCs go up to basically anything.
Reply 18 of 39, by Sphere478
I like the backplane idea. Would be a very fun build. Some even had agp!
I think that somewhere there is such a thing as a pentium 4 AT motherboard but I can’t find it, (aside from the sbc/backplane option)
Sphere's PCB projects.
Reply 19 of 39, by Big Pink
Sphere478 wrote on 2021-12-30, 00:50:
A scant few images of the Commate P4XB are out there.
I thought IBM was born with the world
