First post, by Enchurito
So I have access to two older computers. I have an amd 486 dx4 100mhz in an acer acros with only isa on the board using a socket 3. I also have access to a pentium 1 200mhz with mmx in a socket 7 board by asus with both PCI and ISA. I plan to dual boot probably using a compact flash or sd card reader. (or maybe an old disk on module ssd). I have various sound cards such as an awe64, a vibra16, and an ess card. I have also considered buying an Orpheus card. I own an RA-50 by roland (an mt32 with a sequencer attached), a MT200 (which is a sc-55 with a sequencer on it) and a Yamaha MU90R. I want to mostly play old point and click games, maybe lemmings, some strategy games. The main question comes down to which of these two machines would be best for dos 6/windows 3.1/windows 95? I have a third machine that I will use for windows 98 (an athlon 1ghz pentium 3 equvilant). So this one will be for just those older games.
